Best frame rate to uprez Beta SP to 720p or 1080i
Christian Moriarty
on Mar 14, 2008 at 11:35:49 am
Have only done this once now.
Beta SP via A500 SDI
thru Kona 3
720p 59.94
Results edited fine in FCPro 6
but...
Motion would not play the clip in real time as I needed to offset the speeds (ramps)
I have a new job coming up that needs every clip ramped once it becomes HD.
Aaron Neitz
Re: Best frame rate to uprez Beta SP to 720p or 1080i
on Mar 14, 2008 at 4:16:03 pm
Speed ramps?? Like 150%?
What I do with SD footage is ingest as 24fps. Have Final Cut strip 3:2 on ingest by capturing on the A frame. Then you can work in a 720/24fps timeline and the Kona with output a clean 59.94 by duplicating frames.
