The selected device has no output controls
Joe Murray
on Feb 26, 2008 at 5:57:35 pm
My audio is coming out of my RCA's hot again. Went into> system prefs>sound to turn it back to unity.
When Aja Kona is selected I get "The selected device has no output controls"
I zapped the pram and reinstalled the Kona software & upgraded to 5.1 while I was at it.
No Joy.
Any ideas
Jeremy Garchow
Re: The selected device has no output controls
on Feb 26, 2008 at 6:07:59 pm
Are you talking about your system sounds?
Disable your Kona for system sounds.
Joe Murray
on Feb 26, 2008 at 6:18:15 pm
All sounds. QT playback, system sound, web sound, FCP sounds. It makes no difference whether I play system sounds through the card or not - but I cant really see why I shouldnt as it is only the RCA's
Dual 1.25 MD, FCP 4.02, CW4, 1.25GB RAM, DUAL ATTO, Medea RT480 QT6.3
Jeremy Garchow
on Feb 26, 2008 at 6:22:35 pm
What I am saying is your should not route your system sounds through your Kona. Make your selected output built-in, not Kona.
Jeremy
Joe Murray
on Feb 26, 2008 at 6:23:44 pm
Sorry to be dim, but why not?
Jeremy Garchow
on Feb 26, 2008 at 6:35:12 pm
[Joe Murray] "Sorry to be dim, but why not?"
For the reasons you are experiencing. If you make your system sounds part of your Kona, that means you can control the relative volume of your incoming and outgoing Kona levels with the system volume control. If you want to hear system sounds through your audio monitors, it's best to run a cable out of your headphone jack on your mac and in to your mixer. That way your levels won't be adjusted on the Kona when you want to crank your iTunes, or whatever.
Jeremy
Joe Murray
on Feb 26, 2008 at 7:04:45 pm
Thanks.
