Newbie Question on Format Conversion Kona 3
Paul Burgess
on Feb 24, 2008 at 3:01:07 pm
Is there anyway that i can use a Kona3 card to convert on QT file on my hard drive to another format also save on the hard drive without exporting the clip outside?
Jeremy Garchow
Re: Newbie Question on Format Conversion Kona 3
on Feb 24, 2008 at 7:29:44 pm
hey paul. Can you please explain exactly what you are trying to do?
What codec to what codec?
Paul Burgess
on Feb 24, 2008 at 9:40:11 pm
Thanks for your response.
An example would be that I have PAl DV file on the disc and want to convert it to any HD format so that I end up with say a QT HD version of the file.
Paul
Jeremy Garchow
on Feb 25, 2008 at 1:14:45 am
No. The Kona only works with feeding video signals to it not with Quicktime files on disc. If you feed a DV-PAL SDI signal to the Kona3, then you can upconvert and capture a PAL HD file in 1080 or 720. FOr file based upconversions there are plenty of options to choose from. Compressor doesn't a decent job or you can pay for one from a number of companies.
Jeremy
Paul Burgess
on Feb 25, 2008 at 8:20:55 am
Thank you for clearing that up.
Paul
Paul Burgess
on Feb 25, 2008 at 9:37:11 am
When I feed in by firewire from a camera - say a DV source and choose a Kona codec to up convert - will the card then handle the up convert to the disc?
Paul
Jeremy Garchow
on Feb 25, 2008 at 2:41:22 pm
No as you are using the firewire port on the computer, not the Kona card.
Make sense?
Jeremy
Paul Burgess
on Feb 25, 2008 at 2:44:59 pm
Makes sense - I just hoped that using the Kona codec would use the Kona processor.
I was misinformed by the dealer.
Thanks for your help.
Paul
Jeremy Garchow
on Feb 25, 2008 at 3:37:21 pm
[Paul Burgess] "Makes sense - I just hoped that using the Kona codec would use the Kona processor.
I was misinformed by the dealer. "
FOr the majority of it's uses, the KOna uses codecs from FCP. If you feed SDI from a dv deck, you can up-convert your dv signal.
Jeremy
