Kona 3 DSK
Mike Most
Kona 3 DSK
on Feb 8, 2008 at 4:38:39 pm
In trying to put a 2.40 matte over an HD video image, I'm having some trouble with the downstream keyer. For the matte I'm using a 32 bit Targa file with embedded alpha. I set the DSK to be Graphic over Framebuffer and load the file. What I get is partially transparent red where the matte should be, so it's reading the alpha, but only seems to be keying on one signal component rather than YUV. Has anyone successfully used the DSK in HD for a similar use, and do you have any hints? Thanks in advance...
gary adcock
Re: Kona 3 DSK
on Feb 8, 2008 at 6:03:07 pm
[Mike Most] "n trying to put a 2.40 matte over an HD video image, I'm having some trouble with the downstream keyer. For the matte I'm using a 32 bit Targa file with embedded alpha."
Mike
tone down that tiff.
16bit is the current max for the keyer.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
Mike Most
Re: Kona 3 DSK
on Feb 8, 2008 at 7:06:49 pm
Thanks, Gary.
I tried using a Tiff and that worked.
