TC window from AJA Card!!! Did I miss this??
Ron Thompson
on Feb 8, 2008 at 3:35:10 pm
TODAY I just discovered that I can playback a realtime TC window from FCP!!! Am I an idiot??? Or was this in the recent upgrade and I just missed it? For years I've been using the TC Generator filter in FCP. Today I ran a TC burn from a QT file, but forgot to turn off the TC option in the AJA control panel. I launch FCP, and what do you know, the TC window is chasing my timeline!! This has been a source of discussion here for a while, just thought I'd share. Thanks AJA!!!
First the Giants win the Superbowl, now this!!! :)
Feel free to trash me if I've been missing out for months!! Bob, you go first!! LOL
Ron
RIOT Productions
G5, Kona LH, FCS2, CalDigit
Jeremy Garchow
Re: TC window from AJA Card!!! Did I miss this??
on Feb 8, 2008 at 4:03:51 pm
I won't trash ya, but it's been there for a while. It was there before timecode was officially supported in Quicktime. Nice huh?
Jeremy
Ron Thompson
on Feb 8, 2008 at 5:08:21 pm
Thanks Jeremy...I definitely missed it. I knew you could get TC from the QT file, but I MISSED this little FCP feature! What a time saver!
RIOT Productions
Jim Blokland
on Feb 8, 2008 at 6:01:40 pm
Definitely cool feature. But mine seems to add 2 HOURS to the hour mark -- but only when playing. During pause, the code is accurate. Anyone else get this? Or is there a setting somewhere I'm missing?
BTW, this is on a 720p 23.98 timeline with DVC PRO HD material.
Thanks in advance.
Best, JIM.
OSX.4.10
Dual 2.7 G5
3.5 GB RAM
Radeon X800 XT
Kona 2 / K-Box
Seritek 1.5 TB RAID
AVID XPRESS PRO/MOJO
Jeremy Garchow
on Feb 8, 2008 at 7:20:42 pm
Check the "use QT Timecode" box.
Jim Blokland
on Feb 8, 2008 at 8:10:48 pm
Hi Gary:
Yes, I've got the Use QT Timecode box checked, and the input set to RP188 LTC (if that matters). I should also mention that I'm using a Kona 2 with the latest greatest driver set, and I'm using Quicktime 7.3 with Tiger 10.4.11 and FCP 6.0.2.
Still doesn't work properly when playing.
Any other ideas?
Best, JIM.
OSX.4.10
Dual 2.7 G5
3.5 GB RAM
Radeon X800 XT
Kona 2 / K-Box
Seritek 1.5 TB RAID
gary adcock
on Feb 8, 2008 at 6:00:47 pm
[Ron Thompson] "ODAY I just discovered that I can playback a realtime TC window from FCP!!! Am I an idiot??? Or was this in the recent upgrade and I just missed it?"
No comment....
it has been hidden since the 3.1 driver I think.
did you note that you can generate TC, use the QT code or change the TK burn in to show alternate frame rates ( rates from 24 - 60 fps are available)
guess what- there is a pref panel that can be accessed also....
the DS Keying function can be used to show a bug onscreen, as stills or motion...
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
Jim Blokland
on Feb 8, 2008 at 6:05:35 pm
Okay, I spoke too soon. Now when I play, it just flips to an arbitrary code...not sure what's going on...
Doesn't seem to matter what settings I use on the Control Panel...
Best, JIM.
OSX.4.10
Dual 2.7 G5
3.5 GB RAM
Radeon X800 XT
Kona 2 / K-Box
Seritek 1.5 TB RAID
Ron Thompson
on Feb 8, 2008 at 6:59:13 pm
[gary adcock] "it has been hidden since the 3.1 driver I think.
HAHAHA...wisenheimer! Yes I knew every and anything about the preference panel other than the fact that TC works with FCP!
Now that I know this, yes, I just discovered the alternate frame rate output which is cool. Thanks
RIOT Productions
Ron Thompson
on Feb 9, 2008 at 1:48:21 am
Now that I've over used this feature today (LOL....and a producer today said, wow! timecode, great!!) A follow up question is, can this signal be sent down a RS422 line?? or is it only a video output? Sadly I returned my rental too fast and couldn't check.
RIOT Productions
Jeremy Garchow
on Feb 9, 2008 at 3:31:44 am
AS in send that to the deck for sequence timecode? I doubt it. I can check tomorrow. Have to do the ole tc match up manually I'd guess.
Jeremy
Ron Thompson
on Feb 9, 2008 at 5:30:35 am
Thanks jeremy.
RIOT Productions
Christopher S. Johnson
on Mar 1, 2008 at 12:43:51 am
Right. This is almost useless and only shows arbitrary timecode until you pause. It does NOT read the Quicktime or Sequence timecode until paused.
Oh well.
-Christopher
Ramona Howard
on Mar 1, 2008 at 1:01:52 am
It isn't the AJA board. We are getting burn-in timecode via the board in RaveHD while playing or paused. We can pass a variety of timecode options, i.e embedded, absolute or LTC (which is via the LTC board in RaveHD).
Cheers,
Ramona
Jim Blokland
on Mar 1, 2008 at 12:31:28 pm
Hi guys:
So am I to understand that this feature works for some people but not for all? If so, any hints as to making it work for me? : > )
Best, JIM.
OSX.4.10
Dual 2.7 G5
3.5 GB RAM
Radeon X800 XT
Kona 2 / K-Box
Seritek 1.5 TB RAID
