Is the new driver safe?
Don Wilson
on Jan 25, 2008 at 6:23:53 am
I've not installed the V5 drivers as I'm still on Tiger. But there are some issues the new press release mentions that would help me. As well, I've read of recent problems with the V5 drivers and wonder if these new and improved ones are safe?
Best to all,
Don Wilson
Don Wilson
donwilson.tv
AmericanaMediaInc.com
MississippiSon.com
818.660.2915 studio
818.207.6924 cell
818.760.1828 fax
David Brier
Re: Is the new driver safe?
on Jan 25, 2008 at 4:43:09 pm
I tried installing version 5.0 in Tiger, and it simply did not work form me (FCP crashed at startup). I was told that, in fact, 5.0 is Leopard only, despite AJA's claim to the contrary. I will wait to here if that's changed for 5.1 (they still say Tiger compatible). I do like the sound of "improved Edit to tape frame accuracy in all interlaced formats", although I've not run across this issue.
David Brier
http://www.postopmedia.com
Jeremy Garchow
on Jan 25, 2008 at 4:58:09 pm
I have 5 up and running on Tiger.
What happened?
Jeremy
David Brier
on Jan 25, 2008 at 5:22:25 pm
Here's the old thread for reference:
http://forums.creativecow.net/thread/98/868388
But basically, after uninstsalling v 4 drivers, installing v5 drivers, and deleting prefs, Final Cut would crash on startup when it tried to load a Kona setup. Everytime. As you can see in the thread, I was told that it was not actually Tiger compatible. Any ideas?
MacPro 2.66 GHz Quad Core
12 GBs RAM
Internal SATA storage
Kona 3
FCP v 6.0.2
OS 10.4.11
Quicktime 7.3.1
David Brier
Warren Eig
on Jan 25, 2008 at 5:40:04 pm
AJA told me not to use version 5 with Tiger. They said stick with 4. Use v5 for Leopard.
Warren
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.babyboompictures.com
http://www.atomfilms.com/af/content/knitwits
http://www.atomfilms.com/film/family_xmas.jsp
Jeremy Garchow
on Jan 25, 2008 at 5:47:16 pm
Really? That's weird. Guess I should revert.
Jeremy Garchow
on Jan 25, 2008 at 6:21:38 pm
I just spoke with AJA and apparently someone made a mistake. The v5 drivers are definitely Tiger compatible. i am running v5 on tiger on everything seems to be fine.
Jeremy
Warren Eig
on Jan 25, 2008 at 6:31:19 pm
[Jeremy Garchow] "I just spoke with AJA and apparently someone made a mistake. The v5 drivers are definitely Tiger compatible. i am running v5 on tiger on everything seems to be fine.
This is what tech support told me. They said if you are running Tiger stick to v4. I guess if depends on who you speak with.
Warren
Warren Eig
O 310-470-0905
Jeremy Garchow
on Jan 25, 2008 at 6:35:39 pm
I think someone made a mistake. It happens!
Jeremy
David Roth Weiss
on Jan 25, 2008 at 6:32:26 pm
Jeremy,
I was using the ver 5 drivers with Tiger too without any issues. Of course now that I'm a bleeding edge user I'm running Leopard, also without issues...
David
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los Angeles
A forum host of Creative COW's Business & Marketing, and Indie Film & Documentary forums.
David Brier
on Jan 25, 2008 at 6:48:54 pm
Can you think back to what QT version you were running on Tiger?
David Brier
Jeff Bernstein
on Jan 26, 2008 at 10:27:46 am
The only weird 5.1 issue we are seeing is with After Effects. We can't get realtime playback of HD material in a RAM preview. v4 and v5 did not have this issue.
It's as if the graphics card is an AGP card with bandwidth limitations. Turning off AE's Video Preview "solves" the issue.
Jeff Bernstein
Digital Desktop Consulting
Apple Pro Video VAR
XSAN Certified
MetaSAN Master Reseller
323-653-7611
Jeremy Garchow
on Jan 26, 2008 at 5:20:46 pm
I am sure you know this already, but is your AE preview window @ 100%?
Rich Rubasch
on Jan 27, 2008 at 6:39:18 pm
I loaded ver 5.1 on a Tiger G5 Dual 2.7 non intel with ah LH and it completely solved my sync drifting problems outputting component to Betacam on long sequences. Just in time too!
Haven't given it a good workout in AE etc, but for me, after uninstalling 4.0, it has behaved very nicely. But I had real sync problems outputting to Beta and 5.1 clearly solved them.
Rich Rubasch
Tilt Media
Greg Jones
on Feb 1, 2008 at 4:07:33 pm
I was having a lot of 'popping' noises with the Version 4 driver. When I updated to 5.1 it seemed to have solved the problem. I'm running Tiger, becuase I was having too many issues with Leopard.
Greg Jones
D7,Inc.
Orlando,Fl.
http://www.d7-inc.com
Greg Jones
Orlando,Fl.
