K3-Box cable length
Mathieu Marano
K3-Box cable length
on Jan 21, 2008 at 2:37:44 am
Hi, I will receive my Kona 3 next week and I want to wire my patch before it gets here. Anybony knows the length of the cable that goes between the Kona 3 and the K3-Box?
Mathieu Marano
online editor - motion graphics - Post-prod director
Directeur technique de post-production
Le Bureau de post production
Administrator of the Montreal Final Cut User Group
http://www.finalcutmtl.org
john ladle
Re: K3-Box cable length
on Jan 21, 2008 at 7:51:47 am
2 Meter cable is standard,
when you use the break out box on any of the models, an optional 5 meter cable is available if required.
Bob Zelin
on Jan 21, 2008 at 3:35:41 pm
you should assume that the cable length is going right to your MAC computer, since the cable AJA supplies is SHORT (it's shorter than 2 meters).
You will run the following cables to your bay -
HD IN 1
HD IN 2
HD Out1
HD Out 2
Analog Out Y
Analog Out R-Y
Analog Out B-Y
Reference IN
Audio Out L (with an RCA plug)
Audio Out R (with an RCA plug)
RS422
more lines, if you use AES/EBU audio.
Bob Zelin
Mathieu Marano
on Jan 21, 2008 at 9:03:20 pm
I will also put the AES in the patch because I will go thru an ADA4 and a D10AD to output to and capture from BetaSP.
Oh, and my SRW5500 is my second machine room. I have to run 70 feet of cable from the Kona to the SRW5500. Should I put a DA in the middle of the line?
Mathieu Marano
Bob Zelin
on Jan 21, 2008 at 9:57:31 pm
Mathieu writes -
REPLY -
NO - use Belden 1505A or Belden 1694 cable, and you will have NO PROBLEMS - you ABSOLUTELY DO NOT need to DA the signal. This will work fine. Do NOT use cheap cable. (Gepco VPM-2000 cable or Canare L-4CFB cable will work great also).
Bob Zelin
Mathieu Marano
on Jan 22, 2008 at 7:00:29 pm
Thanks Bob
Mathieu Marano
