Aja Kona 2 & kona 3 with Sony XdCam
John Wilson
on Jan 16, 2008 at 5:02:02 pm
I am trying to get a Sony XDcam format to play out of a Kona 2 or a Kona 3. I have tried numerous formats coupled with multiple Kona settings and been unsuccessful. I have, however, been able to play many of the XDcam formats out of Final Cut using the "Aja: 1080i 29.97 8bit" setting, regardless of the clip format. Unfortunately I can't use Final Cut for my end product and I need to play out of VirtualVTR or at least AjaTV (for now). Any ideas on how to get any XDcam format to play out of a Kona 2 or 3 from AjaTV or VirtualVTR?
John Wilson
john.wilson@byu.edu
BYU Broadcasting
Jeremy Garchow
Re: Aja Kona 2 & kona 3 with Sony XdCam
on Jan 16, 2008 at 6:55:41 pm
That setting is correct for output. 1080i 8 bit for 1080i material that is not 10bit.
Jeremy
John Wilson
on Jan 17, 2008 at 4:11:53 pm
If that is the correct setting, any ideas to why it doesn't work then?
gary adcock
on Jan 17, 2008 at 5:32:21 pm
[John Wilson] "f that is the correct setting, any ideas to why it doesn't work then?"
have you check to see if the video out is on?
this is the most common problem
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
John Wilson
on Jan 17, 2008 at 7:00:31 pm
What do you mean "on"? In AJATV maybe? The video out is set to Aja Kona.
gary adcock
on Jan 18, 2008 at 6:26:11 pm
[John Wilson] "What do you mean "on"? In AJATV maybe? The video out is set to Aja Kona."
AJA TV has nothing to do with FCP.
do you have the video out turned on in the application you are working in- it does not just happen by itself.
in FCP that would be View > external video> all frames.
AJA TV DOES NOT SUPPORT HDV of any type, and that would include EX footage.
gary adcock
Studio37
gary adcock
on Jan 17, 2008 at 2:43:54 pm
[John Wilson] "Any ideas on how to get any XDcam format to play out of a Kona 2 or 3 from AjaTV or VirtualVTR?"
Only the non Native QT code supported by AJA TV is DVCPROHD so that will not work.
not sure about VTR exchange.
gary adcock
Studio37
