1080 cross conversion question
Aaron Neitz
on Jan 14, 2008 at 9:46:54 pm
I'm finishing a music video in 1080/23.98. In delivery specs they specifically want 1080/29.97
I see Kona 3 doesn't have the option to do this conversion (23.98 to 29.97i). Would you simply add 3:2 in After Effects?
Jeremy Garchow
Re: 1080 cross conversion question
on Jan 15, 2008 at 12:54:06 am
Oh yes it does. SImply change your video output in FCP to 1080i (8 or 10 bit).
Sweet huh?
gary adcock
on Jan 15, 2008 at 12:54:23 am
[Aaron Neitz] "I see Kona 3 doesn't have the option to do this conversion (23.98 to 29.97i)."
yes it does set the output to 29.97 and the card adds the pulldown.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
Aaron Neitz
on Jan 15, 2008 at 1:16:28 am
Ah, thanks lads, was not aware!
In all my HD travels, have never actually needed to make 1080i from 1080p. I don't have a deck till tomorrow to experiment - is there anything I need to do timeline wise to layoff (23.98 fps to 29.97 HDCAM)
Jeremy Garchow
on Jan 15, 2008 at 1:20:50 am
Nope. this conversion is done in hardware by the Kona.
It's handy.
Be sure that your pulldown pattern is set up properly in your Kona control Panel.
Jeremy
Doug Beal
on Jan 16, 2008 at 4:14:36 pm
I sometimes need to deliver several versions from a master. I prefer to master 1080Psf 23.98 to HDCam and do the conversions from the deck. 1080Psf 23.98 will let you go anywhere
Jeremy Garchow
on Jan 18, 2008 at 4:20:33 pm
NO Doug, you are insane! Why the eff would you EVER work in 23.98? You work in TV! Everything is base 30, don't you know that?
Just kidding.
Jeremy
