Images goes darker on pause
Pierre Tremblay
on Jan 8, 2008 at 8:18:53 pm
Hi there,
I'm using a Kona 2 (driver 3.4) in a G5 dual 2gHz, OS 10,4,11. Whenever I pause in FCP,
the image goes darker on both my CRT (component) and my LCD (HD-SDI to AJA HDP to
ACD 23"). This happens whether I'm in SD or HD. How can I correct this?
Thanks.
Pierre Tremblay
Jeremy Garchow
Re: Images goes darker on pause
on Jan 8, 2008 at 8:55:56 pm
What codec?
Pierre Tremblay
on Jan 8, 2008 at 9:00:51 pm
It seems to be independent of the codec. Right now I'm in DVCPro-HD,
but it does the same in SD 8 or 10 bit uncompressed. Is this normal?
Could it be the analog output format setting (Component SMPTE?EBU N10)?
Pierre
Jeremy Garchow
on Jan 8, 2008 at 9:05:33 pm
No, it shouldn't be. Try turning off your range check (control-z).
Jeremy
Pierre Tremblay
on Jan 8, 2008 at 9:09:30 pm
Bingo! Thanks.
Pierre
