New Kona 3 v5 Software Woes
David Brier
on Dec 28, 2007 at 7:42:44 pm
I have not been able to successfully run the latest Kona 3 software version 5. I've run the AJA uninstaller, restarted, ran the v5 installer, restarted, trashed preferences (although this is done automatically during install), launched FCP, and chose a Kona setup in the presets dialog box, and then BAM! FCP disappears with no "Unexpectedly Quit" box. If I choose a plain DV setting at first, and then choose a Kona setup after FCP startup, I am able to work for a bit before the inevitable crash. I know this is offered as a Leopard update, but AJA says it should work with Tiger. I've since gone back to v4, and have been good to go, but I was wondering if anyone else is having this issue?
Mac Pro
Quad Core 2.66 GHz
12 GBs of RAM
Quicktime 7.3.1
FCP v 6.0.2
David Brier
http://www.postopmedia.com
David Brier
Re: New Kona 3 v5 Software Woes
on Dec 28, 2007 at 9:40:13 pm
Sorry, running OS 10.4.11.
David Brier
Warren Eig
on Dec 28, 2007 at 10:52:44 pm
David,
I was told by AJA not to upgrade to 5.0 if you are running 10.4.1.1. v5.0 of the drivers is really for Leopard.
Warren
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.babyboompictures.com
http://www.atomfilms.com/af/content/knitwits
http://www.atomfilms.com/film/family_xmas.jsp
David Brier
on Dec 30, 2007 at 12:51:24 pm
Warren,
That was what I suspected, but still the website claims Tiger compatibility for v5, and thus the confusion. Version 4 is still a happy place, so no lost sleep here.
Thanks again,
David
David Brier
Jeremy Garchow
on Jan 25, 2008 at 5:27:47 pm
Hmm. After uninstalling. Did you have any Kona presets left over? Even custom ones?
ALso, after uninstalling go in to your library receipts and trash anything to do with AJA or KOna. Restart. Then run the installer again.
Jeremy Garchow
on Jan 25, 2008 at 6:23:09 pm
Apparently there's been a mistake somewhere. I just spoke with AJA and v5 of the drivers are most definitely Tiger compatible.
Jeremy
