audio delay since version 5
Itamar Kool
on Dec 14, 2007 at 12:37:36 pm
Since I have version 5 of the AJA Kona driv ers, I have an audio delay of about 2 frames. Changing the frame off set in the System Settings hasn't helped, nor trashing the preferences
Kool En De Anderen
MAC Pro 8 core/Kona LHe/Apple FCS 2/Adobe PPCS3/Huge fibrechannel
http://www.koolendeanderen.nl
Itamar Kool
Re: audio delay since version 5 NO MORE
on Dec 14, 2007 at 4:38:25 pm
Just opened the project again and now everything is in sync....
Haven't done anything with it. Never mind
Kool En De Anderen
Jeremy Garchow
on Dec 14, 2007 at 5:13:05 pm
Just curious, is you media 24p Sd by any chance?
Itamar Kool
on Dec 14, 2007 at 5:18:29 pm
It's a project shot with the Sony XD Cam at 25p. The codec is PAL 625/IMX at 50 mb.
Kool En De Anderen
Jeremy Garchow
on Dec 14, 2007 at 5:23:25 pm
Cool. Thanks.
Itamar Kool
on Dec 14, 2007 at 5:26:52 pm
You made me curious. What does this mean??
Kool En De Anderen
Jeremy Garchow
on Dec 14, 2007 at 5:42:23 pm
Nothing. There's a weirdness floating around with ether FCP, Quicktime, or something that writes to Quicktime with 23.98 SD material, at least that's what has been effected so far. I haven't hear of any other format/frame rate being effected.
Jeremy
Mark Palmos
on Dec 14, 2007 at 5:58:07 pm
Hi
Im getting a very strange thing happening, the PAL Video monitor is about 2 or 3 frames ahead of the computer playback! Very strange... on version 4 the video monitor was always behind the computer plyback, and sometimes it was a whole second behind!
This is a massive shortcoming of Aja, the Matrox Axio suffers no lag at all. It is impossible to use the Aja Kona Lhe for cutting to music because the sync issues are so bad.
5.0 seems to have improved, but it is still off - weird that it is AHEAD of the computer though!
Mark.
Jeremy Garchow
on Dec 14, 2007 at 6:07:16 pm
[Mark Palmos] "This is a massive shortcoming of Aja"
Hold on, take a deep breath, relax, now let it out.
This is not a short coming of AJA, it's matter of FCP not being set up properly. Notice how I didn't blame you there?
Go to Final CUt Pro > System Settings > Playback Control Tab and change the frame offset to -2. If that doesn't work for you, try different numbers until it matches up.
Jeremy
Mark Palmos
on Dec 14, 2007 at 10:26:54 pm
Hi
I will fiddle with those settings, though there are much bigger problems im having with Kona LHE at the moment... but it seems weird that sync can be a whole second out, and scrubbing backwards and forwards is as thogh via a long elastic band, it is extremely un-responsive when compared to matrox axio. (or discreet edit with a targa card for that matter)
ta
mark.
David Roth Weiss
on Dec 15, 2007 at 5:35:54 am
Mark,
Whenever something happens such as what you are describing, you need to unistall the Kona drivers using the uninstall utility, then reinstall. If that's not it, then your slot configuration on the fancy 8-core is somehow forked-up.
David
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los Angeles
A forum host of Creative COW's Business & Marketing, and Indie Film & Documentary forums.
Mark Palmos
on Dec 15, 2007 at 1:28:18 pm
hi deeardubbleya
ive now done a fresh install of leopard and it is different from how it was on tiger.
tiger with v4 drivers would sometims be a whole second behind on the PAL monitor, and sometimes just a few frames. Scrubbing was always sluggish and there has alwasy been a lag of some kind.
the leopard install is very odd, firstly because the PAL monitor is AHEAD of the computer display (no idea how that is possible) and more of a problem is the terrible crashfest I have loading FCP projects with motion anims in them.
hopefully i will be a happy camper again soon...
cheers,
mark.
