AJ-1400 audio issues
Paul
by
on Dec 4, 2007 at 5:39:51 pm
Hi-
Wondering if there are any known audio issues with outputting HD 1080i to the AJ-1400. I know the FW output has its issues but I'm coming out SDI from my Kona LHe into the HD SDI on the deck. Video is all good but the audio is "crunchy" for lack of a better term. Material was brought in via FW but I'm outputting from the card (I didn't have the card when I digitized) and wondering if that's giving me this nonsense...
Any thoughts?
Thanks.
JeremyG
Re: AJ-1400 audio issues
on Dec 4, 2007 at 5:51:13 pm
Call AJA right now.
Jeremy
Paul
by
on Dec 4, 2007 at 5:58:15 pm
will do. strange thing is I outputted to digibeta with no issues....
JeremyG
on Dec 4, 2007 at 6:03:51 pm
Yes, it's intermittent.
Jeremy
walter biscardi
on Dec 4, 2007 at 5:58:38 pm
No issues at all here using HD-SDI to layback.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.
STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow!
Read my Blog!
Simon Sommerfeld
on Dec 4, 2007 at 6:23:50 pm
Hi Paul,
I've had something similar to what you're describing happen with a Kona2. I tracked it down to a setting in the Kona control panel. One of the Kona SDI inputs fed from a deck was selected as the input source but the deck wasn't turned on. Darn thing caused static in the audio. I deselected the SDI and the audio was clean. Could be a different scenario from you, but worth looking at.
Best,
Simon.
Simon Sommefeld
Redwood City CA
Paul
by
on Dec 4, 2007 at 7:26:18 pm
My penance......
DOH!
Operator error.
Broke the first rule of troubleshooting by not checking my connections. Breakout box cable somehow became loosened. Seems to have fixed the issue.
As always thanks so much for the quick responses.
-Paul
JeremyG
on Dec 4, 2007 at 8:43:08 pm
[Paul] "DOH!
Operator error. Breakout box cable somehow became loosened. Seems to have fixed the issue. "
Oh, you mean it was one of those EASY fixes?
Huff. Puff. Huff.
Paul Provost
on Dec 5, 2007 at 5:01:17 am
you're lucky Bob Zelin hasn't seen this post.
you'd get an a?% chewing
Paul
by
on Dec 5, 2007 at 6:17:53 pm
believe me....I know. Problem is it would be deserved. I figured at least I fessed up.
