480p captures with Kona 2?
Saddler
on Nov 26, 2007 at 6:17:48 pm
What are the current solutions for capturing 480p via component using a Kona 2?
Arniepix
Re: 480p captures with Kona 2?
on Nov 26, 2007 at 7:23:49 pm
Same as they were last week. Scroll down 7 threads.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
http://www.arniepix.com/blog
Saddler
on Nov 26, 2007 at 10:21:05 pm
I read the LHe thread, but I need to capture 480p via component.
Bob Zelin
on Nov 26, 2007 at 11:54:01 pm
If you have an AJA Kona 2, you have no ability to capture analog component, so you need a CONVERTER that will convert analog component into SDI.
AJA HD10AVA will do this for you.
AJA I/O will do this for you.
Isn't there something cheaper - no.
Why don't they just make a box that does everything - they do - it's called the AJA I/O HD.
If you are working with analog video, and no HD, you are better off with the Kona LHe or AJA I/O.
Bob Zelin
Saddler
on Nov 27, 2007 at 12:54:30 am
Hmm, okay I have an HD10A that I use for capturing HD, but it doesn't get a signal when I try and input 480p into it and set FCP to capture from AJA 525. Do I have to also purchase a D10A just for 480p SD component? I would like to capture 480p60.
Bob Zelin
on Nov 27, 2007 at 3:05:33 am
Saddler -
this is what you are going to do right now. NO SLEEP FOR YOU until you look at this -
http://www.aja.com/html/products_converters_mc.html
This is the AJA Mini converter line. See that ? The AJA HD10A will not accept a standard def analog component signal, but the HD10AVA WILL ACCEPT a standard def analog component signal and turn it into SD-SDI. This SD-SDI signal can now be put into your Kona 2 SDI Input, where you can capture your analog component information.
START READING.
Bob Zelin
