ProRess codec capture problem.
chinny
on Nov 23, 2007 at 11:11:36 am
I have Macpro 3.0/ATI1900, Mac OS X 10.4.10, FCS2 6.0.1
When captureing the source, I chose Proress codec.
The problem is I couldn't finish capturing with this error message "Tape trouble. Check VTR. Do not attempt to eject tape or use transport without checking VTR first"
And, I checked the captured source to see what happened.
It is out of sync between audio and video.
The weired thing is it just happens if I choose "ProRess codec" .
I am wondering what cause this problem.
For your reference, if I disconnect "REMOTE CABLE" between nle and deck, above issue is not happened.
Thank you in advance.
JeremyG
Re: ProRess codec capture problem.
on Nov 23, 2007 at 10:45:58 pm
Call or write AJA and tell them to email you the patch that disables text polling.
This is not a ProRes problem, it is an FCP problem.
Jeremy
