preview out of After Effects and motion is nasty
Andrew Shanks
on Nov 14, 2007 at 10:41:50 pm
Hi guys,
We have got AE CS3 running on a MacPro Dual 3Ghz Quad - Core Intel Xeon with the AJA Kona LH card and previewing thru a new Sony Broadcast Monitor - LMD 2450. The issue we're having is that Ram Previews on full resolution within a 16bit project (as we are working with 10 bit source material) previews text and vector graphics as if it is low resolution and aliased ....footage is fine. Same thing for RAM previews in Motion.
If we render this out and view it in Final Cut Pro, the quality is fine and looks good. Anyone got tips for settings for optimum playback and preview as it would look once rendered ?
In the prefs - Video Preview, Output quality is set to More Accurate. Using OpenGL. Adaptive Resolution Limit is set to 1/8
Cheers,
andrew
