Running into Kona 3 problems that require hard reset
mr.escandon
on Oct 26, 2007 at 7:07:12 pm
We've just upgraded to 8-core Mac Pros with Kona 3 cards and I'm running into a problem every so often where the Kona 3 will not output video properly and the only way to fix the problem is to shut down (not reset) and manually turn the computer back on. When the Kona 3 is exhibiting this problem the output on the screen is generally garbled.. but never the same way or the same color. Also, trying to use Final Cut almost always results in a crash...
As of now this is just a hassle - but I'm hoping it is not a sign of a bigger problem to come or some hardware or software incorrectly configured.
The question that I have is does any one know of a way to potentially "Reset" the Kona settings or have it re-load into the system without having to do a hard reset? I can't seem to figure that out if there is such a way...
Thanks.
gary adcock
Re: Running into Kona 3 problems that require hard reset
on Oct 26, 2007 at 9:03:44 pm
Ok
what OS, FCP and Kona Drivers
it is not possible to read your mind on the config?
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
mr.escandon
on Oct 26, 2007 at 10:34:11 pm
My Kona drivers are 3.4, my OS is 10.4.10, and I'm running Final Cut 5.1.4.
gary adcock
on Oct 26, 2007 at 10:57:55 pm
the 3.4 drivers are not recommended for 10.4.10 and QT 7.2 but the upgrade wants an intel processor.
gary adcock
Studio37
mr.escandon
on Oct 26, 2007 at 11:11:53 pm
The AJA site says:
AJA Driver Compatibility as of KONA Version 4.0 is as follows:
FCP 6.0.x (Final Cut Studio 2)- Kona Driver version 4.0
FCP 5.1.x - Kona Driver versions 3.1 through 3.4
FCP 5.0.x - Kona Driver version 3 (first Universal Binary version)
So I can't really upgrade to 4.0 since I'm still running 5.1.4 based on this... oh and I am using QT 7.2 also.
JeremyG
on Oct 26, 2007 at 10:06:12 pm
Have you run the PCIe Config Utility?
mr.escandon
on Oct 26, 2007 at 10:34:35 pm
No, can you please tell me what/where this utility is?
JeremyG
on Oct 26, 2007 at 10:49:27 pm
HardDrive > System > Library > CoreServices > Expansion Slot Utility.app.
Select option#2 and restart.
Jeremy
mr.escandon
on Oct 26, 2007 at 11:10:22 pm
Oh yes I did just try this after reading it on the AJA site. I'll see if I still notice the problem since this change.
