K2 Breakout box with K3 Board?
David Battistella
on Oct 24, 2007 at 2:31:00 pm
Does anyone know if this is possible?
David
walter biscardi
Re: K2 Breakout box with K3 Board?
on Oct 24, 2007 at 3:09:40 pm
No, the connections are completely different on the K3.
Walter Biscardi, Jr.
http://www.biscardicreative.com
Stop Staring Start Grading with Apple Color The new Color Training DVD now available!
http://store.creativecow.net/p/66/stop_staring_and_start_grading_with_apple...
Read my blog! http://blogs.creativecow.net/WalterBiscardi
JeremyG
on Oct 24, 2007 at 3:44:35 pm
But the Kona 3X board works with the Kona 3e for all future posters/cow searchers.
Bob Zelin
on Oct 24, 2007 at 8:55:55 pm
David
I've got bigger problems than the K2 box with the Kona 3. Like when will the Kona 3 (and Kona 2) work with Leopard. And when will the SCSI/Fibre/SATA host card drivers be written for Leopard. This is the stuff that will stop you dead in your tracks.
Bob Zelin
Xiaolom
on Oct 25, 2007 at 11:28:18 am
I read in another thread somewhere, that the K3 had issues with the MacPro. You could only run max 2 Gb of Ram to be able to work with the K3.
Is this true and has this been adressed by aja in the meanwhile??
because we intend to purchase a K3 and run it in a Mac Pro with 4 GB Ram.
Bob Zelin
on Oct 25, 2007 at 1:03:52 pm
the only issue is running Pro Res with the Kona 3 on a MAC Pro with more than 2 Gig of RAM. If you are doing ANYTHING ELSE, (uncompressed, DVCProHD, uncompressed SD, etc.) there are no issues, and you can have as much RAM as you like.
Bob Zelin
szumlins
on Oct 25, 2007 at 1:16:17 pm
It should be noted that this problem does not occur with every 8 Core MacPro either. Mine runs just fine with more than 2Gb of RAM and ProRes with a K3.
gary adcock
on Oct 25, 2007 at 1:38:45 pm
[Xiaolom] "I read in another thread somewhere, that the K3 had issues with the MacPro. You could only run max 2 Gb of Ram to be able to work with the K3. Is this true and has this been adressed by aja in the meanwhile?? "
the 2 gig limit is an issue with 4:4:4 and 2K RGB workflows only and it is an issue in QT not in the Kona Driver.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
JeremyG
on Oct 25, 2007 at 3:39:37 pm
I don't use 4:4:4 RGB. But I have not had a problem with 16GB in an 8 core.
FInal Cut 6 does some really weird things, but the Kona seems fine.
Jeremy
David Battistella
on Oct 28, 2007 at 4:19:54 am
Thanks for the responses folks.
Hey Bob,
ATTO has released their drivers for Leopard (they probably write the aplle drivers for them too).
Now I just need every one of my other 27 applications to be compatible and things will be great!
Any word on whether K2 will ever work with Leopard?
David
