SD downconvert issue - AJA LHe
Xiaolom
on Oct 24, 2007 at 10:48:26 am
Hi cow,
I
szumlins
Re: SD downconvert issue - AJA LHe
on Oct 24, 2007 at 2:05:19 pm
Is your output in FCP set to Hi-Def still.
FCP 6 has the added "benefit" of allowing you to output to the card even if your timeline is setup incorrectly.
Make sure FCP is set to Hi-Def output and control panel is set to downconvert on the output you need.
Xiaolom
on Oct 25, 2007 at 11:48:16 am
Great it works!
Thanks for your input!
