AJA IO HD and Color?
Russell Lasson
on Oct 19, 2007 at 6:04:19 pm
Any word if it's going to work as an output for color?
-Russ
Russell Lasson
Re: AJA IO HD and Color?
on Oct 19, 2007 at 6:14:51 pm
Just realized I posted in the Kona forum and not the IO forum. Silly me. It's mostly the same readers so what do you think?
-Russ
gary adcock
on Oct 19, 2007 at 7:01:25 pm
[Russell Lasson] "Any word if it's going to work as an output for color? "
the IoHD is currently only able to output live as SD (both NTSC and PAL) from Color.
this is a limitation of Color at this time.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Russell Lasson
on Oct 19, 2007 at 7:22:22 pm
hmmmm...........
-Russ
walter biscardi
on Oct 19, 2007 at 7:31:46 pm
[gary adcock] "this is a limitation of Color at this time."
Considering Color doesn't even support firewire at this time, this is a huge step forward by AJA.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
Russell Lasson
on Oct 19, 2007 at 8:09:01 pm
I agree. I was secretly hoping that AJA and Apple had worked things out and that we'd see Color 1.0.2 come out.
But alas, not yet.
-Russ
walter biscardi
on Oct 19, 2007 at 8:46:51 pm
[Russell Lasson] "we'd see Color 1.0.2 come out."
This has nothing to do with AJA and everything to do with Apple. Leopard is so close that there will probably be a slew of updates released for the Studio Suite right after that happens. Of course you'll have to be running Leopard to take advantage of them.
We'll know in about a week.
gary adcock
on Oct 19, 2007 at 8:12:57 pm
[walter biscardi] "Considering Color doesn't even support firewire at this time, this is a huge step forward by AJA."
no question.
it's also what Color uses from its render preview - since the previews in Color default to 1/2 or 1/4 rez you are actually viewing the preview render at size the size that apple sends it out.
I have yet to hit a AJA wall with IoHD, a bunch from apple, but none from the AJA side.
FCP 6.01 still does not see LTC timecode when capturing- you have you use AJA's VTR exchange to capture LTC timecode direct from the cameras.
gary adcock
Studio37
