A few Kona 3 Questions
Erik Lindahl
on Oct 18, 2007 at 7:27:36 am
We are investigateing if we should go with a Kona 3 or a Kona LHe board on our next editing suite so I have a few questions to ask regarding this.
1. Does the Kona 3 offer a better "video desktop" experience? The Kona LHe is quite sluggish in this regard and perhaps the future is more promosing for Kona 3 here
walter biscardi
Re: A few Kona 3 Questions
on Oct 18, 2007 at 11:24:41 am
[Erik Lindahl] "1. Does the Kona 3 offer a better "video desktop" experience? The Kona LHe is quite sluggish in this regard and perhaps the future is more promosing for Kona 3 here
Bob Zelin
on Oct 18, 2007 at 9:00:54 pm
your problem is with your drives, or crap loaded on your computer. The Kona 3 will NOT perform better than the Kona LHe (but it will give you upconversion).
Crappy drives give you crappy performance. Run AJA Kona System Test now. If you dont' get over 170mb/sec on whatever drives you are running, stop complaining, and change your drive arrays.
I use the Kona 3 for AE realtime outputs all day long, and it works just fine.
The Kona 3 is not a miracle product, if your drives are full.
If you own Lacie drives, well, you are on your own.
Bob Zelin
BrianT
on Oct 20, 2007 at 6:24:54 pm
Follow up on drives as I'm close to upgrading to producing more HD projects. I currently have a 1TB SATA drive array. I realize money plays a factor, but what drive arrays do you recommend?
70% of our projects are done in 8bit uncompressed
30% of our projects are done in DVCProHD 1080i60 or 720
Obviously, the later is painstakingly slow as we still just have a G5 Dual 2.7
Thanks in advance.
Bob Zelin
on Oct 20, 2007 at 8:10:17 pm
If money is really an issue, you can get away with FW800 drives (like from G-Tech, etc.). If you have a little more money, you can get an "old school" (2 year old technology) SATA port multipier product for PCI-X from Cal Digit, Sonnet, Dulce, Firmtek, etc. This will give you much better performance. A better investment for new systems are the newer RAID 5 SATA arrays, but since you have a PCI-X based MAC, you can't get these for your system. When you upgrade to a newer PCI-E based MAC, you simply get a PCI-E SATA port multipler card for your MAC, and continue to use your drive array.
But if money is the only issue, you can continue with FW800 for what you are doing.
Bob Zelin
Colin McQ
on Oct 21, 2007 at 4:36:26 am
Hey Bob, read your review on the S2VR HD you wrote back in Jan. It might be the way I go for in a new suite:
Macpro octo (8 gig ram)
2X23"ACD
Kona LHe with breakout box
S2VR HD
Are you still liking the S2VR HD or have you seen anything else similar in price and performance spike your interest? How about the G-SPEED eS?
Caldigit S2VR HD VS G-Tech's G-SPEED eS
Any thoughts?
Colin McQuillan
Vancouver BC
walter biscardi
on Oct 21, 2007 at 11:28:34 am
[Colin McQ] "Caldigit S2VR HD VS G-Tech's G-SPEED eS"
Gary Adcock's honestly the only person I know of who runs the GSpeed but he loves it.
I had three S2VR HD's fail on me in less than 6 months. I was a huge fan of them at first, but obviously this performance soured me on them.
We now run 8TB SAS/SATA arrays from Maxx Digital which top out around 460MB/s in RAID 5.
We also have two LaCie S2S 1.25 TB SATA Arrays that have been a workhorse for over 2 years now on various sytems.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
gary adcock
on Oct 21, 2007 at 1:23:18 pm
[Colin McQ] "How about the G-SPEED eS? "
as walter said, I do like my Gspeed ES unit.
I prefer Fibre over Sata do to the mass connectivity in my office- FIbre allows me to plug in any array to my Q-logic switch and instantly see it over the network- a plus when you see as many storage solutions as I do.
I am currently awaiting a demo unit from Dulce ( SAS based) and I also have a test unit arriving later in November from Ciprico. I have not tested the Caldigit or Sonnett solutions.
SATA is great if it is only one machine- it is nearly impossible to share a Sata array across multiple computers, hense the reason I use fibre.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
cowcow
Bob Zelin
on Oct 21, 2007 at 2:28:56 pm
I don't like Gary's response (no offense Gary).
Gary's response suggests that you purchase a QLogic Fibre Switch, plug all your fibre workstations into it (along with
your Fibre array), and VOILA, everyone sees everything including the storage, just like a simple ethernet network. It does not work this way, and requires system configuration and operation of a SAN solution - anything from XSAN to MetaSan, and countless others. You just don't "plug in" and all of a sudden, you "instantly" see it. SATA and Fibre are just disk drive arrays, and without a solution that allows you to share, you just don't get to plug in and share efficiently.
Bob Zelin
Colin McQ
on Oct 21, 2007 at 6:54:55 pm
Hi Guys,, thanks for all the response,
Fiber would be great,, but this particular unit is for a suite that will live in my den and the SATA raid will only be used on the one station. Might lug the system out to the truck for a few broadcasts here and there, but will mainly live at home.
For cost/performance, I've narrowed my search to the two units i've listed above. The S2VR HD and the GSPEED eS
The more I read... the more I like the GSPEED... According to them you can get write speeds up to 560MBs and read speeds over 600MB/s!! (with 4 units striped together in raid 0.) Is this possible with the S2VR? Couldn't find anything on this on the caldigit site...
GSPEED eS is capable of RAID 0,1,5,10,JBOD, S2VR HD is RAID 0,1, JBOD
GSPEEDes is a bit cheeper than the S2VR HD.
I know of Walter's experience with the S2VR HD, although I have read many good things about it too! (Really!?! you had 3 units go south on you?!?)
On the other hand the GSPEEDeS is new,, and I cant find any solid reviews on it,, and don't know anyone who has tested one...
Are there other units in this range I may have missed that contend with these two?
Colin McQuillan
Vancouver BC
walter biscardi
on Oct 21, 2007 at 7:33:15 pm
[Colin McQ] "I know of Walter's experience with the S2VR HD, although I have read many good things about it too! (Really!?! you had 3 units go south on you?!?)"
3 died in 6 months and CalDigit could never recover the media for us. If it wasn't for us religiously backing up the data to a LaCie FW800 unit, we would have been totally screwed.
Bob still likes them though.
gary adcock
on Oct 21, 2007 at 7:43:16 pm
[Colin McQ] "The more I read... the more I like the GSPEED... According to them you can get write speeds up to 560MBs and read speeds over 600MB/s!! (with 4 units striped together in raid 0.)"
I have NEVER been able to attain that kind of throughput with less than 10 drives in an array- it cannot be done.
My speed tests on the 6 drive unit were about 295 MBps sustained asynchronous transfer - more than fast enough for 1080 4:4:4 RGB but not enough for 2K.
gary adcock
Studio37
Colin McQ
on Oct 21, 2007 at 8:26:27 pm
[gary adcock] "I have NEVER been able to attain that kind of throughput with less than 10 drives in an array- it cannot be done."
Should have been more clear,, by 4 units I meant 4 GSPEEDeS stacks (each with 4 drives for a total of 16 individual drives in 4 units)
each unit/stack (4drives) in raid 0 is rated I think 207MBs write and 227ish read, but apparently you can add up to 4 stacks to the G-Tech 4-Port, PCIe x4 RAID Controller for a total of 16 drives to get the 600+MBs read speeds
Colin McQuillan
Vancouver BC
gary adcock
on Oct 22, 2007 at 11:11:13 am
Sorry Not a Sata guy,
I prefer fibre because I want a redundant backup, I cannot recommend any storage for HD that does not have the ability to be redundant in case of drive failure.
gary adcock
Studio37
walter biscardi
on Oct 22, 2007 at 11:57:34 am
[gary adcock] "I prefer fibre because I want a redundant backup, I cannot recommend any storage for HD that does not have the ability to be redundant in case of drive failure."
That's why all of the major SATA units run RAID 5 to RAID 10 these days. My Maxx Digital units are both set up in RAID 5 and during testing we popped a drive out during 10bit Uncompressed HD capture. The units kept right on humming.
So if redundancy is your main concern, you can achieve that with SATA today.
Colin McQ
on Oct 21, 2007 at 7:00:33 pm
oh snap!
Sorry Bob,, I may have accidentally rated your post... low... I was going for a tab in my browser and had a premature click... The "Rate This Post" was right there.... I tried to give you 5 cows after,,, but it wont let me :-(
Anyone reading,, could you help me out! Give bob some cows for his post just above!!
Cheers,
Colin McQuillan
Vancouver BC
gary adcock
on Oct 21, 2007 at 7:38:55 pm
[Bob Zelin] "Gary's response suggests that you purchase a QLogic Fibre Switch, plug all your fibre workstations into it (along with your Fibre array), and VOILA, everyone sees everything including the storage, just like a simple ethernet network."
Tough Bob,
The reality is no, there is no such thing as plug and play with any kind of Multiuser environment, and I never said that all I did was snap my fingers and "poof" everything was config'd
However, I was able to configure the array, install software, switch and fibre connections in about 1/2 day. This is about what YOU would need for 2 of your own machines considering how many machines the both of us have configured for the usage in the past. This was not blind faith, it was just experience.
If this was an Xsan it would have taken 2 days and 3 computers to do what I did with my 2- Macs, the Metasan software and a single Gspeed ES unit in less than 6 hours.
gary adcock
Studio37
