Kona LS connection options
ajayb21
on Oct 14, 2007 at 9:31:26 pm
Hi there,
I'm using a Kona LS card after deciding to ditch a Datavideo Firewire conversion unit. I've got the Kona BOB and am monitoring via Component through my monitor. However, is there a way to send my signal to a VHS/DVD combo unit at all? The converter I used to use had both Component and Composite outputs so is there any way I can achieve this with the Kona?
szumlins
Re: Kona LS connection options
on Oct 15, 2007 at 2:58:33 pm
You would have to either convert one of your SDI outputs to an analog signal or monitor via composite or YC while outputing via the other. Can't do component and composite at the same time. You can do composite and Y/C though.
