Color not outputing the visual to my broadcast monitor
ycngjack1
on Oct 9, 2007 at 3:19:44 am
Guys,
please help.
http://img300.imageshack.us/my.php?image=picture1uz0.png
i suppose using AJA Pro IO pal 25 8 bit, but i cant select any output to go to my broadcast monitor. As picture shown above, disable is the only choice. please tell me wat to do....
thanks..cheers!
Bob Zelin
Re: Color not outputing the visual to my broadcast monitor
on Oct 10, 2007 at 1:31:34 am
Make your your AJA Pro I/O box is working. Do NOT use Final Cut Pro to test your box. Use the AJA Pro I/O Control Panel to test your I/O Box.
Play your VTR into the Pro I/O box - select the correct input (composite, component, SDI), and you should see a picture on your broadcast TV monitor. Do not use Final Cut Pro until you have this working.
Bob Zelin
ycngjack1
on Oct 10, 2007 at 3:01:33 am
my AJA pro IO alwyas work as i always use it in FCP. Just wonder y cant it apply to Color? is it possible maybe Aja IO not supported by Color yet?
walter biscardi
on Oct 10, 2007 at 9:07:37 am
[ycngjack1] "my AJA pro IO alwyas work as i always use it in FCP. Just wonder y cant it apply to Color? is it possible maybe Aja IO not supported by Color yet?"
Firewire devices do not work with Color yet so the Io will not work. However I've been told that the the Io HD WILL work with Color right out of the gate.
Also, we have an AJA Io forum so you don't need to post Io questions in the Kona forum.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
gary adcock
on Oct 10, 2007 at 12:33:10 pm
Read the Color doc's
No current FW devices are supported with Color.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
