Does Exporting Current Settings Add Compression?
Nick Tempest
on Oct 8, 2007 at 2:49:55 am
Please forgive if this isn't the right place for this.
I have a Kona, running on an Intel based power mac.
We'll be editing something in 720p. My question is, if we export our final sequence as a quicktime movie with 'current settings', is it going to compress the movie more than it already was as clips in the sequence?
In other words, does exporting a movie add compression?
Or would it be better to make a DVC PRO HD tape as a master? Is THAT compressed as well?
Looking for a way to make a master to take to color correction shop that is not compressed any more than it already was as I was editing it.
Jared Picune
Re: Does Exporting Current Settings Add Compression?
on Oct 8, 2007 at 12:00:56 pm
As long an you don't select recompress all frames, you will not add additional compression when using export QuickTime movie (using current settings). Make sure to select make movie self contained.
