Photoshop and Kona 3 question
Bob Zelin
on Oct 2, 2007 at 9:48:08 pm
Hi -
If you use Adobe After Effects with the Kona 3, you can have AE do a video preview thru the Kona 3 card by changing the preferences.
So, HOW DO YOU DO THE SAME THING with Adobe Photoshop (and importing into After Effects or Final Cut Pro is not the answer I am looking for). How do you get Adobe Photoshop to diplay directly on an NTSC monitor via the Kona. Another
not-acceptable answer is to go into the Kona Control Panel, select and under Control tab, select MACINTOSH DESKTOP, and drag the photoshop window into this "third" monitor. This is not an acceptable answer.
Anyone ?
Bob Zelin
walter biscardi
Re: Photoshop and Kona 3 question
on Oct 2, 2007 at 11:20:03 pm
[Bob Zelin] "Another
not-acceptable answer is to go into the Kona Control Panel, select and under Control tab, select MACINTOSH DESKTOP, and drag the photoshop window into this "third" monitor."
That's actually how I've been doing this all along. Honestly have not looked at PS3 to see if it support a Video Preview like After Effects does. I'll check that in the morning.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
John Pale
on Oct 2, 2007 at 11:25:39 pm
[Bob Zelin] "How do you get Adobe Photoshop to diplay directly on an NTSC monitor via the Kona. Another
Anyone ? "
Oh boy. The only answers are non-acceptable. The only way to do this via the Kona is through the Kona Desktop function. You CAN display a video preview out of Photoshop via Firewire, as Photoshop CS has that capability built in. The video preview feature of Photoshop does not support cards however, only firewire.
Guess I am a dead man.
walter biscardi
on Oct 3, 2007 at 11:21:28 am
[John Pale] "The video preview feature of Photoshop does not support cards however, only firewire."
Yep, that's what it says in the Help menu. Drag and drop over to the Desktop Display is still the only way or bring the image into After Effects.
Bob Flood
on Oct 9, 2007 at 2:22:12 am
hiya guys!
Echo Fire by Synthetic Aperture will display the Photoshop "canvas" out the kona card, and not by the desktop cheat either.
there is a macro which will export the photoshop "canvas" to
kona 3, and can also compnesate aspect ratio, superimpose title safe, and so on. (*the app was developed specifically for video monitor previews of photoshop while working in photodhop.
even though its not as good a product as kona, blackmagic claims it supports photoshop previews as well as ae when you install their devices
hope this helps
"I like video because its so fast!"
Bob Flood
Greer & Associates, Inc.
