AJA to HDMI
Nick Griffin
AJA to HDMI
on Sep 22, 2007 at 2:34:01 pm
First, please excuse my relative ignorance on this, but... What's the best way to connect a high def monitor with HDMI inputs to our Kona LHe breakout box? Thanx.
walter biscardi
Re: AJA to HDMI
on Sep 22, 2007 at 3:46:28 pm
Hi5
http://www.aja.com/html/products_converters_HI5.html
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
Nick Griffin
Re: AJA to HDMI
on Sep 23, 2007 at 10:19:20 am
Thanx, Walter!
David Roth Weiss
Re: AJA to HDMI
on Sep 23, 2007 at 6:10:59 pm
Nick,
I was researching this a few months back and I do recall that there was an issue regarding 24fps playback using the Hi5. You should check with AJA to see what the deal is, or if its been fixed. I suspect that monitoring a 29.97 output from the Kona card would most likely work, but you should probably look into this before buying.
David
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los Angeles
POST-PRODUCTION WITHOUT THE USUAL INSANITY
Nick Griffin
Re: AJA to HDMI
on Sep 24, 2007 at 10:45:51 pm
Thanx, David.
Wow. Advice from TWO of the Cow's most preeminent leaders.
Dave Martin
Re: AJA to HDMI
on Dec 13, 2007 at 8:09:25 pm
I would be interested to know if anyone uses this setup as an edit monitor situation (not color correction)
Dave
Martin
- MacPro - Quad Core - 4 gig Ram
-MacBook Pro - 2.16GHz Intel Core Duo - 2 gig Ram
-FCP Studio 5.1.4 - QT 7 - OSX 10 - Firmtek Sata Raid- G-raid dv drive
