kona lhe HD output problems
gardener
on Sep 17, 2007 at 6:22:50 pm
I have a new Mac pro 8 core running 3 internal drives striped together. I'm trying to output DVCpro HD. The AJA system test says the data rate is sufficient but the video stutters on the SDI output of the Kona card. I've tried to output through the AJA TV with the same result. The setting seem correct. Should this system work? Thoughts?
JeremyG
Re: kona lhe HD output problems
on Sep 17, 2007 at 7:04:54 pm
What does the system test say for speed?
walter biscardi
on Sep 17, 2007 at 7:19:31 pm
What Easy Setup are you using?
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
