Force RGB in Color
Alan Okey
Force RGB in Color
on Sep 14, 2007 at 3:35:25 pm
I recenty discovered that the Force RGB option in Apple's Color is currently not functioning with Kona cards due to a bug in the Kona 4.0 driver. Force RGB offloads RGB>YCrCb conversion to the capture card to lighten the software processing load, which can potentially improve realtime playback performance.
As a current Kona LHe owner and former Blackmagic Decklink owner, thus far I have found AJA to be superior with regard to support and documentation. is it likely that AJA will come out with a bug fix/driver update to address this issue in a timely manner?
walter biscardi
Re: Force RGB in Color
on Sep 14, 2007 at 4:10:15 pm
[Alan Okey] "is it likely that AJA will come out with a bug fix/driver update to address this issue in a timely manner?"
Yep. Should be very shortly.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
