FCP 5.1 and 6 on same system with Kona 3
cmlundy
on Sep 14, 2007 at 1:06:12 pm
If one needed both versions on their systems what might be the best way to do it while maintaining the correct Kona 3 drivers?
I've read adding an additional internal drive to install OSX and FCP6 makes for a less buggy system. This seems the best way to keep the requisite Kona drivers separate as well.
But what if I attempted both FCP versions on the same system drive? Is there a way to get both Kona drivers on there and have them function correctly?
Thoughts?
Chris Lundy
PostWorks New York
JeremyG
Re: FCP 5.1 and 6 on same system with Kona 3
on Sep 14, 2007 at 4:36:54 pm
Keep it separate, it what I do. I have two boot drives, one for FCP5 and one for FCP6 with the different drivers (v3 & v4) on those different boot drives.
Keep your life simple and don't try and mix and match. To choose a different boot drive, simply restart and hold option, a pop up will come up and you arrow to your boot drive and press return.
Jeremy
