Offline capture AJA-IO LA
chrisondoradrive
on Sep 12, 2007 at 2:03:44 pm
I am working in an environment with incredibly limited storage. I am currently capturing roughly 4 hours of industrial footage using the AJA IO LA interface. I can set up Offline Sequence settings but the AJA doesn't seem to have a corresponding Offline Capture quality setting that will keep capture disk space to a minimum and I REALLY MEAN MINIMUM.
I have tried a couple of things but am getting no real space savings. The only thing I can do is capture 8 bit and recompress using Media Manager.
Anybody else with this problem?
Chris
JeremyG
Re: Offline capture AJA-IO LA
on Sep 12, 2007 at 5:33:56 pm
Do you know how to use the Io LA and the easy setups?
Hit control-q and choose form the myriad of inputs and codecs.
I would suggest capturing to DV and not 8Bit. This will also allow real time previews of footage, unlike offline rt.
Hit control-q and choose the AJA IO 'choose an input' 8 bit to dv.
Jeremy
chrisondoradrive
on Sep 12, 2007 at 7:02:07 pm
Hi Jeremy, thanks.
I know about easy setup but I find that the DV codec is looking for a
firewire device and I need to log using RS-422 from BetaCam.
A few days ago I created an easy setup on this same project but in comparing
"original to modified" clip size,I wasn't saving much space on the drive.
Chris
JeremyG
on Sep 12, 2007 at 7:17:40 pm
Have you installed the io drivers?
walter biscardi
on Sep 13, 2007 at 1:36:05 pm
[chrisondoradrive] "I know about easy setup but I find that the DV codec is looking for a
firewire device and I need to log using RS-422 from BetaCam."
Did you simply choose DV-NTSC (or DV-PAL) or did you choose the AJA 8bit to DV Easy Setup? You need to use the AJA Easy Setup.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
