Another CYA Q: K3 + MP Octo upgrade
weevie833
on Sep 4, 2007 at 11:45:11 pm
Current setup:
G5 2.0 DP [2003] PCI-X 4gb RAM, 10.4.9, FCP 5.1.4. with Apple fibre [copper], Kona 2, to XServe RAID 50 2.5 TB.
On second internal HDD: FCS2, 10.4.10
Looking to upgrade to MP 8-core, Kona 3, PCIe Fibre Card, XServe RAID 50 [same RAID}
Anything else I should expect to acquire? Only other option I think would be the HD10AMA for audio conversion.
Would the RAID need to be reformatted for any reason? Any minimum RAM suggestions? I figure 4 or 6gb should be enough.
thx.
steve covello
double wide post
walter biscardi
Re: Another CYA Q: K3 + MP Octo upgrade
on Sep 4, 2007 at 11:49:50 pm
The RAID should not need to be reformatted for any reason, but absolutely back up everything on that array before you make the switch, just in case. Might not be a bad idea to simply wipe that array clean and then put all the media back on it when you make the switch.
Absolutely, positively don't switch machines until you're at a comfortable place in your production schedule to deal with any unforseen issues. Better yet, if there's a way to start running your new machine while keeping your old machine active at the same time, that's the best way to make the transition. I was able to do that with our transition to the Mac Pro.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
