SATA II RAID/HD question
tPIX
by
on Sep 1, 2007 at 1:36:23 am
I might have to set up an HD suite again, sold the last one off 2 years ago.
Can a SATA II Raid do 1080i 59.94 10-bit HD uncompressed at this time? Last time I could only get 8-bit HD playback which was two years ago on a dual 2.7 G5, PCI-X.
I have a Quad 2.5Ghz G5 pci-e and was planning on using Kona hardware again.
Thanks in advance for any help
Bob Zelin
Re: SATA II RAID/HD question
on Sep 1, 2007 at 8:49:34 pm
you could have done it back then (2 years ago) with 8 - 10 drives. The rules have not changed. Because you have the old MAC G5 dual 2.7, this is PCI-X. ATTO and Cal Digit do not make RAID 5 cards for PCI-X, so you can either get the Dulce 8 bay RAID 5 SATA array with the PCI-X card, or you can get a RAID 0 solution from Cal Digit - the S2VR with the FASTA-4X SATA host card. You can use anyone elses RAID 0 Sata solution, if you have 8 - 10 SATA drives, all striped RAID 0. Any of the new RAID 5 solutions will work, but all but the Dulce are PCI-E, and you have PCI-X.
You will also now need the AJA Kona 3X card - the Kona 2 is no longer made. And why do you need 10 bit uncompressed HD?
ProRes422HQ is not good enough for you ?
Bob Zelin
tPIX
by
on Sep 5, 2007 at 12:24:33 pm
Hi Bob,
Thanks for your response...
I have no problem with the new apple Prores HD codec solution, and hopefully it will gain general acceptance quickly, because I love my old io...and the new io looks sweet...
but my clients want to hear the word uncompressed...and I always color correct in 10-bit.
I like to build my own systems because I am a cheap b*stard, so...
Here's what I was thinking of doing:
-Two five bay Kano SATA port multiplier chassis, with WD 750 Gig Raid Edition drives, for ten drives in total striped as a single raid0 volume.
-I have two of the Sonnet 4 channel pci-e sata cards, so the the raid could be across two slots if necessary. I already have these cards so hopefully they are adequate and I won't have to purchase something else.
-I would use one of the two available choices for an AJA HD card...haven't decided yet.
My current machine that I want to use is actually a...
G5 Quad 2.5, {PCI E), 8 Gigs RAM, Internal 1.5Tb SATA RAID 0 system disk.
what do you think? Good enough for 1080i 10 bit?
walter biscardi
on Sep 5, 2007 at 12:41:05 pm
[tPIX] "
I like to build my own systems because I am a cheap b*stard, so..."
There's a thread right above discussing Fibre vs. SATA for uncompressed with a lot of information regarding SATA for HD
http://forums.creativecow.net/readpost/98/866754
I would never build my own arrays as there are too many good companies out there doing that for us and I like the idea of calling them for tech support if something goes wrong. We're now running two SAS/SATA arrays from MaxxDigital which are running well over 450MB/s, more than enough for 10bit HD.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
