Compressor Failure
Don Wilson
Compressor Failure
on Aug 30, 2007 at 6:49:53 am
New Problem.
Used Compressor many times recently. Now I cannot get it to boot up. Crashes on launch every time. Any insight is greatly appreciated.
Don Wilson
MacPro 3g
Kona 3
Multilane Sata Raid
Scssi Raid
FW 800 Maxtor 1 TB x 2
etc etc etc
JR-Links
Re: Compressor Failure
on Aug 30, 2007 at 9:08:57 am
Apple has posted an info doc that actually works.
(reinstalling Compressor is tricky, but compared with the alternative of reinstalling everything, it's a lot less time consuming)
weevie833
on Aug 30, 2007 at 2:46:06 pm
Try trashing Compressor .plist file:
[user]/Library/Preferences/com.apple.compressor.Compressor.plist
steve covello
msacci
on Aug 30, 2007 at 3:02:30 pm
I had a problem with compressor and the document did the trick. Needs to be followed closely, there is a lot more to compressor then just compressor.
Don Wilson
on Aug 30, 2007 at 8:35:00 pm
Thank you all. The Apple thread did the trick. I'd used an App Delete program but obviously it didn't delete everything. The re-install did the trick so again my thanks.
The Cow Rocks again!
Don Wilson
AmericanaMediaInc.com
MississippiSon.com
