FLYING COW POWER SUPPLY?
Jim Blokland
on Aug 20, 2007 at 12:46:03 pm
Hi Cow-ers:
Anyone with a Flying Cow 24-bit convertor out there know what amount of DC power supply it needs, or if one can still be purchased somewhere? Would you mind checking and getting back to me?
Thanks in advance.
Best, JIM.
OSX.4.3
Dual 2.7 G5
3.5 GB RAM
Radeon X800 XT
Kona 2 / K-Box
Seritek 1.2 TB RAID
AVID XPRESS PRO/MOJO
walter biscardi
Re: FLYING COW POWER SUPPLY?
on Aug 20, 2007 at 1:07:54 pm
On the back of the AC Adapter it says:
OEM AC Adapter
Model AA-091A5
Input 120VAC 60Hz 20W
Output 9 VAC
However, where it actually plugs into the back of the Flying Cow unit, there is no +/- legend telling me whether the ring is hot or the center is hot. If you don't get the proper format you'll fry the box. You can easily get a new power supply at Radio Shack or Fry's, but I have no idea how to test which way that plug is set up.
If you need a new unit, you can also look at AJA's ADA4 converter box which we also have here in our second suite. It's a bi-directional A/D audio converter as well.
http://www.aja.com/html/products_converters_ADA4.html
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
Jim Blokland
on Aug 20, 2007 at 1:14:40 pm
Thanks for the quick reply Walter.
I would normally consider the AJA box, but I've got an opportunity to pick up the Flying Cow (sans power supply) for $20 CDN! Perhaps I could get the info from the folks at M-Audio...
One more question, when it says Output 9 VAC, does that mean the power supply is actually A/C? I would have assumed that most of these supplies are converting A/C to D/C current...
Thanks again for any further insight.
Best, JIM.
OSX.4.3
Dual 2.7 G5
3.5 GB RAM
Radeon X800 XT
Kona 2 / K-Box
Seritek 1.2 TB RAID
walter biscardi
on Aug 20, 2007 at 1:17:23 pm
[Jim Blokland] "One more question, when it says Output 9 VAC, does that mean the power supply is actually A/C"
that's how I'm reading it. VAC would be A/C
Scot Olson
on Aug 20, 2007 at 4:02:40 pm
I don't have one but if it is A/C, then polarity will not matter.
Jim Blokland
on Aug 21, 2007 at 12:53:23 am
It definitely is A/C, as Walter suggested. I'm trying to track one down from M-Audio via a local supplier, just to make sure it works.
Thanks for all the help folks.
Best, JIM.
OSX.4.3
Dual 2.7 G5
3.5 GB RAM
Radeon X800 XT
Kona 2 / K-Box
Seritek 1.2 TB RAID
