Kona 3 hanging up
Patrick Troy
Kona 3 hanging up
on Aug 18, 2007 at 2:14:44 am
Hello
Dual Quad macPro
FCP 6.01
Sanman Raid
Im trying to digitise Digi Beta into a large project.
The project is mostly HD > Apple ProRes ~ 50 hrs
with some DV, HDV and Digi BEta
I captured a couple of hours of Digi Beta in 2 weeks ago but it had an interlace problem.
We have the deck back and I want to recapture that stuff correctly and also some new stuff.
I cant seem to capure more than a 3 second grab.
Ive been trying for hours on different settings but Im stumped
Any ideas?
regards
Patrick
walter biscardi
Re: Kona 3 hanging up
on Aug 18, 2007 at 11:05:17 am
The 3 second grab has nothing to do with the Kona and everything to do with your drive setup. Generally that is a result of dropped frames due to slow drives. I've not heard of Sanman Raid.
What are the results of the AJA System Test?
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
David Roth Weiss
on Aug 18, 2007 at 1:33:36 pm
[walter biscardi] "The 3 second grab has nothing to do with the Kona and everything to do with your drive setup. Generally that is a result of dropped frames due to slow drives. I've not heard of Sanman Raid."
Walter,
In theory, Patrick's drive setup should fly -- Sanman raids use up to 16 SATA drives with a U320 SCSI controller. He has 4Tb according to his profile. After looking at his other posts I'm guessing he's got a hardware issue such as his PCI configuration or drivers.
As you suggest, he should run the Drive Speed test first to see what kind of throughput he's getting.
David
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los Angeles
POST-PRODUCTION WITHOUT THE USUAL INSANITY
Patrick Troy
on Aug 18, 2007 at 10:33:29 pm
Hi
thanks for replies
I used the AJA system test and all the results seem very good
Kona 3 DMA Write 112mbs read 135mbs
Sanman @ 512 MB - write 137mbs / read 76mbs
read exisitng file - 222 mbs
should I download kona drivers and reinstall?
Patrick
David Roth Weiss
on Aug 18, 2007 at 10:59:16 pm
[Patrick Troy] "I used the AJA system test and all the results seem very good
Sanman @ 512 MB - write 137mbs / read 76mbs"
Those numbers are not actually very good Patrick. For example, the numbers I'm geting here are:
single SATA drive - write 41mbs / read 38mbs
two SATA drives striped - write 78mbs / read 74mbs
4 SATA drives striped - write 178mbs / read 190mbs
How many drives do you have striped together?
[Patrick Troy] "should I download kona drivers and reinstall?"
Why not give it a try, the latest updates messed up my Kona drivers. Uninstall first and then reinstall the latest drivers. The uninstaller is in your Kona applications folder.
David
David Roth Weiss
Director/Editor
Los Angeles
Patrick Troy
on Aug 18, 2007 at 10:50:31 pm
update
when I capture onto the internal 500gb
its all good
what are factors that can affect the RAID?
David Roth Weiss
on Aug 18, 2007 at 11:09:17 pm
[Patrick Troy] "what are factors that can affect the RAID?"
The biggest factors are, 1) you might need the latest drivers for your raid controller, 2) your raid is getting full, 3)one of your drives is dying and is slowing down all others.
David Roth Weiss
Director/Editor
Los Angeles
Patrick Troy
on Aug 18, 2007 at 11:45:25 pm
David
the RAID started off with 3.18Tb free
it now has 63 GB spare
what would you recommend as optimum max capaxity?
walter biscardi
on Aug 18, 2007 at 11:58:00 pm
[Patrick Troy] "the RAID started off with 3.18Tb free
what would you recommend as optimum max capaxity?"
That's WAY too full. At 75% full, any array takes a speed hit. At 90% full, many arrays will have issues with capture and playback.
One of my biggest questions for you is how long have you been using this array since the last time you erased it? Fragmentation will play a big issue as you fill up the array.
I think your array is simply too full. Is there anything you can get rid of? Do you have any other drives you can dump the media off on to so you can erase your array to clean it up?
Patrick Troy
on Aug 19, 2007 at 12:15:49 am
Walter
the array was bought specifically for this project so it hasnt been erased before and Im hoping fragmentation is at a minimum.
However
there is still 1/3 of the project to capture in ProRes .
Im afraid its a case of first time director not being able to make decisions until he sees drafts etc and not wanting to be ruled by technical considerations so is capturing virtually everything and keping it.
I was going to ask for more HD space this week.
As Ass Editor i suppose
I must be more insistent about the process and put foot down on these type of issues because they wont know if I dont tell, right.
Hmm
learning curve.
thanks for help
wiill capture to internal drive today untill i max it out too, then get more space
regards
patrick
David Roth Weiss
on Aug 19, 2007 at 12:18:13 am
[walter biscardi] "That's WAY too full. At 75% full, any array takes a speed hit. At 90% full, many arrays will have issues with capture and playback."
Walter is correct...
Remember, you heard it here first, a full SATA array is neither good for man nor machine.
David
David Roth Weiss
Director/Editor
Los Angeles
walter biscardi
on Aug 19, 2007 at 1:16:12 am
[David Roth Weiss] "
Remember, you heard it here first, a full SATA array is neither good for man nor machine."
And that's one reason why we just jumped from 1.25TB SATA arrays in our two main suites to 8TB SAS/SATA arrays in both suites. I don't think we'll ever go beyond 5TB at any one time, but we have plenty of overhead to ensure we don't run into any speed issues down the road.
