Can AJA KONA can output HDV sequence to HDCAM deck via HD-SDI?
kutmasta
on Aug 2, 2007 at 4:36:06 pm
Can AJA KONA can output HDV sequence to HDCAM or any othe HD format deck with HD-SDI in via HD-SDI
so that I can avoid the nightmare of outputting via firewire as it is.
and any issue of doing that?
thank you.
walter biscardi
Re: Can AJA KONA can output HDV sequence to HDCAM deck via HD-SDI?
on Aug 2, 2007 at 4:43:10 pm
[kutmasta] "Can AJA KONA can output HDV sequence to HDCAM or any othe HD format deck with HD-SDI in via HD-SDI
so that I can avoid the nightmare of outputting via firewire as it is."
Yes, choose Easy Setup that says AJA Kona HDV Playback settings.
[kutmasta] "and any issue of doing that?"
None that i know of, though you probably need to make sure everything is rendered. I've only used this preset in tests outputting the image to our monitors and it worked perfectly.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
