KONA LHe Workflow
TVJuniorTD
KONA LHe Workflow
on Jul 31, 2007 at 7:08:42 pm
My photog has a new HDCAM HD and I have the KONA LHe. He would like to shoot 1080 24p and I need to edit 525 60i. AJA told me that I need the KONA 3 card - crossconversion. Is there a workflow work around.
I was thinking that I could HDSI out the deck with pull-down, but I am not utilizing the FAM mode of the deck.
Any Suggestions
Junior
JeremyG
Re: KONA LHe Workflow
on Jul 31, 2007 at 7:32:27 pm
1080>525 is actually a down conversion and the LHe should be able to handle it. You should edit in 1080p, but monitor in 525. Are you going to be bringing in the tapeless files?
Jeremy
TVJuniorTD
on Jul 31, 2007 at 8:47:48 pm
You are correct, but I also need to go from 24p>60i.
Junior
JeremyG
on Jul 31, 2007 at 8:59:01 pm
That's still a down conversion and should be do able on an LHe.
Jeremy
Shane Ross
on Jul 31, 2007 at 11:35:23 pm
It is going FROM 525 to 1080p that the LHe cannot do...and that the Kona 3 is suited for. Also going from 720p to 1080p and vise versa that ALSO requires the Kona 3.
But everything you require, as Jeremy says, the Kona LHe can handle
Shane
Littlefrog Post
http://www.lfhd.net
TVJuniorTD
on Aug 5, 2007 at 7:26:26 am
We would like to utilize the tapeless files.
