Unrendered Motion files when duplicating Seq in FCP6
RARudio
on Jul 25, 2007 at 2:12:24 am
Hi Guys,
I just upgraded to FCP6 and I noticed that Motion files rendered in FCP6 becomes unrendered when I duplicate the sequence (this didn't happen in FCP5). Any thoughts... settings? Thanks in advance!
Roland
John Pale
Re: Unrendered Motion files when duplicating Seq in FCP6
on Jul 25, 2007 at 2:34:21 am
There have been widespread reports of FCP 6.x losing render files with duplicated sequences, and I have experienced it myself.
A workaround that has done the job for me is copy/paste into a NEW empty sequence instead of duplicating the sequence.
JeremyG
on Jul 25, 2007 at 4:23:35 pm
John,
Does that fix it all the time? Is it always reliable or does FCP eventually lose it's way?
John Pale
on Jul 25, 2007 at 5:33:43 pm
Its worked for me on at least a dozen sequences within one project.
I don't think that qualifies as extensive testing, but I am think it says something.
J
JeremyG
on Jul 25, 2007 at 6:01:05 pm
[John Pale] "but I am think it says something."
Sure does.
Thanks.
RARudio
on Jul 26, 2007 at 2:22:12 am
Thanks John. When you say copy/paste, you mean copying and pasting the entire sequence?
Roland
John Pale
on Jul 26, 2007 at 4:12:10 am
Yes. Instead of duplicating it, select its entire contents and paste it into the new empty sequence.
Havent had a problem since I started doing this. Your milage may vary.
Jim Watt
on Jul 28, 2007 at 10:42:53 pm
Our work around for this problem which happens frequently is to output the sequence to a QT movie, then it's indestructable.
We've also had many instances of all our other motion renders being destroyed when we open a motion file with the "open in editor" command from the timeline.
jw
