Kona LHe and FCP 6
Joseph Dobek
Kona LHe and FCP 6
on Jul 24, 2007 at 10:39:23 am
I have a Mac Intel - 8 Core running Final Cut Pro 6.0.1. I shoot mainly in Panasonic's 720/24Np format (HVX200 with P2 cards). I monitor using a consumer LCD HDTV (Magnovox - Innovision). The card is hooked up to a Sony Beta UVW1800 VTR.
I use the SDI2 out of the card - running into a SDI to Component AJA converter - then into the RGB input of the monitor.
I am unable to get a clean signal to the Beta deck - right now all I get is a black and white image - not synced (the image stays at about 10% lower then where it should be).
I am able to see an image on the monitor only when it is in 525i - not 720/59.98.
I just put this system in. I had a G5/FCP 5.1 running a Kona 2 card, with the K-Box. I was able to monitor - right out from the K-Box. I used the SDI to Analog to go to the Beta. Everything worked great in this set-up.
What am I doing wrong/missing?
Shane Ross
Re: Kona LHe and FCP 6
on Jul 24, 2007 at 4:13:48 pm
Are you downconverting the signal to the beta deck? You need to do that in the Kona Control Panel...set it to 525i.
Littlefrog Post
© 2018 All Rights Reserved
