1080sf23.98
lumiere
1080sf23.98
on Jul 19, 2007 at 7:50:47 am
For some reason, since I've upgraded to 3.4 Kona Control Panel, I can't get 1080sf23.98 to play ball with FCP.
Kona 3 Control Panel is sending proper bars to the deck in 1080sf23.98.
FCP will play the timeline realtime in 1080psf23.98 no problem but when I Apple-F12 External Video/All Frames, FCP slowly chokes and eventually stalls.
Any insight anyone?
Frederic
P.S. The Deck was switched to 23.98Psf
Jeremy Newmark
Re: 1080sf23.98
on Jul 19, 2007 at 8:13:22 am
Frederic,
What are your system specs?
lumiere
Re: 1080sf23.98
on Jul 19, 2007 at 8:33:07 am
[Jeremy Newmark] "What are your system specs?"
- FCP 5.1.4
- AJA Control Panel 3.4
- QT 7.1.6
- Computer is 2 X 3 GHZ DUAL CORE - 4 GB RAM OSX 10.4.9
- HDW-1800 HDCAM Deck
Frederic
lumiere
Re: 1080sf23.98
on Jul 19, 2007 at 8:36:31 am
Kona 3
Jeremy Newmark
Re: 1080sf23.98
on Jul 19, 2007 at 3:15:40 pm
Do you have tri-level sync?
best regards,
jeremy
gary adcock
Re: 1080sf23.98
on Jul 19, 2007 at 1:34:51 pm
[lumiere] "since I've upgraded to 3.4 Kona Control Panel, I can't get 1080sf23.98 to play ball with FCP."
Fredric
on of the big changes to that control panel was to add support for true P in 1080, so make sure that you are choosing the 1080 sf setup and make sure the Ref is set to video in, on the 1800 I have seen issues with static 29.97 ref and 23.98 signals.
see you in Amsterdam?
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
lumiere
Re: 1080sf23.98
on Jul 20, 2007 at 1:16:01 am
[gary adcock] "see you in Amsterdam?"
Unfortunately I won't make IBC this year. Got 12 shows to finish!!!
