Audio Distorted - Kona 3
lumiere
on Jul 19, 2007 at 2:29:31 am
Any reason why one out of 3 times, the audio coming out of the Kona 3 SDI (via BOB) to HDCAM deck would be distorted (static sound)?
My solution so far has been to restart the transfer (edit to tape) but it tends to creep up sometimes in the middle of a show... Network has already failed a few masters for "distorted audio".
Anyone experienced this before? Any recommendations?
Frederic
JeremyG
Re: Audio Distorted - Kona 3
on Jul 19, 2007 at 3:29:53 am
What versions of everything are you running? (FCP, QT, OS)
Are you running the audio out embedded or analog?
DO the levels in your FCP timeline clip?
Much more info is needed to help diagnose your problem.
Jeremy
lumiere
on Jul 19, 2007 at 3:40:39 am
Jeremy, thanks for taking the time to respond.
Answers to your questions:
- FCP 5.1.4
- AJA Control Panel 3.4
- QT 7.1.6
Audio embedded in SDI (4 channels)
Levels in FCP don't clip and transfer doesn't distort 2 out of 3 times... when it distorts, I simply restart it and it works.
I heard a rumor that it might be a memory allocation issue?
Frederic
JeremyG
on Jul 19, 2007 at 3:43:38 am
[lumiere] "I heard a rumor that it might be a memory allocation issue?"
Don't know about that.
Did you try mixing down your audio first?
What OS are you running and on what computer?
lumiere
on Jul 19, 2007 at 4:02:07 am
I don't want to mix down the audio - need 4 independent channels to the deck Full Mix (1&2) & M&E tracks (3&4).
Computer is 2 X 3 GHZ DUAL CORE - 4 GB RAM
Frederic
JeremyG
on Jul 19, 2007 at 4:08:47 am
Okay, one last time what version of the OS (operating system, OSX, 10.4.?)
Mixing down the audio in FCP does not mixdown the audio in the Avid or audio sense of the word. FCP basically condenses all the audio (in the proper channels that you have assigned) for easier playback. Select your whole timeline and hit command-option-r. It won't ruin anything, I promise. Your channel configurations will remain in tact.
Jeremy
weevie833
on Jul 19, 2007 at 4:17:33 am
I believe this a reference sync issue. I have had this problem with HDCam numerous times about a year ago. this was with K2, so it might not be the same problem.
Damn, I can't remember the magic combination but I think it involves the Control Panel set to Free Run, and then the HDCam deck has to be set to Video In for reference via the Setup menu [F2? F6? Should say so on the display panel]. I'm pretty sure it is that, or try some other combination of HDCam settings while running AJA in free Run.
It annoyed the hell outta me that my Ref in blackburst seemed to be insufficient to make the AJA and HDCam play nice together. Wasted much time getting it right, then remained paranoid ever since.
Sorry I'm being a weenie about the answer, but at least I've had the problem and found a way out of it, so hang in there.
steve covello
lumiere
on Jul 19, 2007 at 4:35:35 am
Steve,
Yes - this sounds like a very plausible solution. I switched to free run on aja and ref - input on the deck.
Haven't had the issue since then but then again, I've only done one master since... will update this post with an update either way.
I think this is very promising and will save me a lot of headache.
THANKS!
Frederic
lumiere
on Jul 19, 2007 at 4:32:52 am
Jeremy,
I don't think you mean using the downmix option in the fcp audio mixer tool... my understanding is that will flatten my 4 channels into 2 and completely ruin my master.
Also, my understanding of command-option-r is just to render a downmix isn't it? It doesn't downmix it.
Frederic
BTW, how do I quote a post when responding?
JeremyG
on Jul 19, 2007 at 4:50:53 am
[lumiere] "I don't think you mean using the downmix option in the fcp audio mixer tool"
No, I don't mean that.
[lumiere] "Also, my understanding of command-option-r is just to render a downmix isn't it? It doesn't downmix it."
Correct. Not in the technical sense of the word.
[lumiere] "BTW, how do I quote a post when responding?
Select the words in the post that you want to quote and hit shift-q.
Jeremy
lumiere
on Jul 19, 2007 at 5:06:30 am
[JeremyG] "[lumiere] "Also, my understanding of command-option-r is just to render a downmix isn't it? It doesn't downmix it."
Correct. Not in the technical sense of the word."
So what does it do exactly that audio render doesn't do?
BTW, looks like Steve's solution: ref in freerun on kona and input on the deck might've worked. Haven't been experiencing the issue since then.
Frederic
Ramona Howard
on Jul 19, 2007 at 7:22:29 am
Frederic,
Haven't seen this issue on our side*. Proper Ref and ref settings play a huge role in getting this all right and can cause a variety of issues, something i'm sure you already know.
Cheers,
Ramona
*We develop our own product using the AJA line of boards
Ramona Howard
on Jul 19, 2007 at 7:32:04 am
Forgot to add:
We are passing both multi channel files (up to 16 embedded) and single channel with no issue out of the board and into decks or any other devices.
One item to consider that hasn't been mentioned is Dolby E. This has to be passed bit for bit otherwise you will have issues. The AJA hardware supports the passing of Dolby E, how FCP handles that I can't help with but maybe someone can chime in that can.
Cheers,
Ramona
lumiere
on Jul 19, 2007 at 7:54:30 am
[Ramona Howard] "Haven't seen this issue on our side*. Proper Ref and ref settings play a huge role in getting this all right and can cause a variety of issues, something i'm sure you already know."
Thank you Ramona - Looks like Steve was right on, Genlock was on refin in Kona, switching it to Freerun seemed to solve the issue.
I do have blackburst going into the BOB.
Frederic
Bob Zelin
on Jul 19, 2007 at 12:31:54 pm
WAIT ! There is absolutely no reason why you should operate any way other than with your Black reference going into your AJA Kona 3 BOB Reference IN, AND the same black reference going into the REF Video input of your HD VTR (and your VTR set for this reference signal - most HD VTR's have selections on the menus for 59.94 or 23.98). Weevie was correct in suspecting a reference issue. I ASSUME that you do have a reference signal going to your HD VTR, and I assume that
your STOP button on the HD VTR is not flashing (indicating no, or improper reference). Is this correct ?
This is not magic - reference your equipment properly and you should have no issues.
Bob Zelin
weevie833
on Jul 19, 2007 at 1:05:13 pm
Bob "the King of Sync" Zelin -
Oh, how I long for the simple days of Avid 11.x, with Ref in to everything and it just works.
Phooey! Not anymore. I tried setting everything to Ref In [AJA, decks] and had OK playback on monitor, but it would not output to DBeta. Had to switch the deck to Video Input, then switch it back to Ref in case someone wanted to output from the Avid [we had both for a while].
Same headaches when we got our HDCam deck. Granted, we were using SD ref in, but there were no issues with playback, striping or digitizing. Only output to tape, no matter which format/frame rate we used e.g. 23.98, 29.97, 59.94 -- which fostered the above solution to this original post.
The necessity to keep the Control Panel in Free Run defies all that I assumed to know up this point with regard to reference sync. Ideally, if I just SPENT THE MONEY [as you would say] for a tri-level sync, I probably wouldn't have any HD problems. But until recently, there hasn't been an affordable product. Thus, my inconvenience.
Surely, you have a solution for my inconvenience, but I've sliced and diced the issue a lot of ways already, and it seems no one solution works all the time. Beat me over the head if you wish.. It is your dharma.
steve covello
Bob Zelin
on Jul 19, 2007 at 10:48:17 pm
1) need affordable tri level sync - the AJA GEN 10 for $390 list price - available now ! Buy it.
2) if you have trouble with genlocking a Digi Beta VTR and the AJA Kona, and it only seems to work when you free run (I had this issue also) - DO NOT LET IT GO - this is either your crappy existing black generator, or a problem with your AJA Kona card. DO NOT LET AJA EVER GET AWAY WITH GENLOCK ISSUES - CALL AND COMPLAIN (I have). Magic work arounds are NOT acceptable - the Kona MUST be able to lock to house sync. If the answer is the new Gen10 - so be it - but you should NEVER accept "free run" as a workaround answer.
No one ever said it was going to be easy.
Bob Zelin
lumiere
on Jul 20, 2007 at 1:20:36 am
[Bob Zelin] "2) if you have trouble with genlocking a Digi Beta VTR and the AJA Kona, and it only seems to work when you free run (I had this issue also) - DO NOT LET IT GO - this is either your crappy existing black generator, or a problem with your AJA Kona card. DO NOT LET AJA EVER GET AWAY WITH GENLOCK ISSUES - CALL AND COMPLAIN (I have). Magic work arounds are NOT acceptable - the Kona MUST be able to lock to house sync. If the answer is the new Gen10 - so be it - but you should NEVER accept "free run" as a workaround answer."
I never thought I had a genlock issue - the issue I had was that once in a while the audio would get scratchy for no reason. Another try would usually fix it. Going "free run" seemed to have fixed my scratchy audio issue.
I'll get the Gen10 and give that a shot.
Frederic
weevie833
on Jul 20, 2007 at 2:27:09 pm
Frederic -
As you've probably surmised by now, the two variables are connected despite it seeming like they wouldn't be.
Digital decks have a funny way of being able to work ALMOST correctly under less than ideal situations because of their ability to conceal/correct. So an incorrect reference signal arrangement will actually cause audio distortions, sometimes minute enough to make you think it's something wrong with something else.
Unless there is A) something fundamentally bad about the source audio itself; B) a bad mix in the FCP timeline; C) something wrong with the AJA card or Mac, you can pretty much count on the problem being bad reference setup.
steve covello
lumiere
on Jul 20, 2007 at 1:14:09 am
[Bob Zelin] "WAIT ! There is absolutely no reason why you should operate any way other than with your Black reference going into your AJA Kona 3 BOB Reference IN, AND the same black reference going into the REF Video input of your HD VTR"
What do you recommend you set the Genlock option in AJA to?
Yes, it doesn't look like the deck is complaining about the reference.
Bob Zelin
on Jul 20, 2007 at 1:43:48 am
I recommend that you set your Kona Control Panel to EXT REF, and not Free Run. If you purchase the GEN10 and own a Kona product, and you have the VTR referenced to external genlock (the GEN10), and your Kona is set to EXT REF (Control Tab in the Kona Control Panel), and you still get audio distortion, complain to AJA.
Bob Zelin
lumiere
on Jul 20, 2007 at 1:49:32 am
Thanks Bob - will give it a shot.
daryl burney
on Jun 30, 2008 at 4:41:17 am
I also have had an ongoing problem with reference between AJA kona and a HDW2000.
I took your advise Bob and am trialing the Gen10...... It doesn't help. The HDCAM deck has no complaints with the trilevel ref. Deck to deck dubs, not a prob. ProTools to HDCAM deck not a prob. FCP to deck... a big problem. THe result is green artifacts and severe channel condition.
It seems the only way to master to HDCAM from FCP with the Kona card is as stated previously in this thread.....
HDW2000 set to reference on video input and FCP to freerun with no HDW2000 return video (this causes a loopback)
KONA it seems to me your card is not HDCAM ready. This method is but a work around. It is an embarrassment to master like this in front of clients. Not to mention tragically unreliable. Audio is often crackly/distorted sounding (also mentioned previously in this thread). Getting proper sync between the Kona card and FCP is just a matter of luck.
I have sung Kona's praises in the past and comverted many from the competition but am now left wondering...
Where is the fix? ....
Daryl
gary adcock
WAS: Audio Distorted - Now REF issue.
on Jun 30, 2008 at 5:55:20 pm
[daryl burney] "KONA it seems to me your card is not HDCAM ready"
Daryl
first off you are Hijacking a thread without changing the title.
I am not seeing these issues and I coming in and out of HDCam decks on a near daily basis. I regularly and recording from JH3 players and SRW series decks without any of the issues you describe.
Each and every time I hear about the REF issue on the 2000 deck I have 2 questions-
has the deck been updated via Sony Service?
are you sure about the settings?
It is only the oldest MDW2000's that exhibit this issue, and it is a harware issue in the deck from everything that I have been told.
Taking the Deck out of E E mode fixes it for most people. (that eliminates the pass thru issue for most)
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
daryl burney
Re: WAS: Audio Distorted - Now REF issue.
on Jul 6, 2008 at 3:43:05 pm
Sorry about the Hijacking!
I will call Sony tomorrow to enquire further about this issue. It is an early model.
Hopefully this will resolve it for me.
thx for your advice
regards
Daryl
Frederic Lumiere
on Jul 6, 2008 at 8:23:09 pm
The AJA Gen 10 properly set to 1080i ref solved the issue for me.
Frederic
Frederic Lumiere
Producer
Lumiere Media
walter biscardi
on Jul 20, 2007 at 1:54:05 am
[lumiere] "Any reason why one out of 3 times, the audio coming out of the Kona 3 SDI (via BOB) to HDCAM deck would be distorted (static sound)?
My solution so far has been to restart the transfer (edit to tape) but it tends to creep up sometimes in the middle of a show... Network has already failed a few masters for "distorted audio"."
Where is the volume set on your Mac? It should not be set to full volume, but about 4 clicks from full volume. This is considered "unity."
That's the first thing I would check in addition to ensuring you're running the latest Kona drivers for your version of FCP.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
lumiere
on Jul 20, 2007 at 1:58:26 am
[walter biscardi] "Where is the volume set on your Mac? It should not be set to full volume, but about 4 clicks from full volume. This is considered "unity.""
I don't use the Kona audio for my Mac's audio output.
I only use the Kona audio in FCP.
-20db tone is perfect on the deck.
Frederic
walter biscardi
on Jul 20, 2007 at 10:22:49 am
[lumiere] "I don't use the Kona audio for my Mac's audio output.
-20db tone is perfect on the deck."
The volume control on your Mac also controls the volume of the audio playback through your Kona card. The volume on your Mac should remain at four clicks from full. I have seen instances of full volume on a Mac causing some distortion on audio playback. that's why I asked. All of our machines are set to "unity."
lumiere
on Jul 20, 2007 at 11:22:05 am
[walter biscardi] "The volume control on your Mac also controls the volume of the audio playback through your Kona card. The volume on your Mac should remain at four clicks from full. I have seen instances of full volume on a Mac causing some distortion on audio playback. that's why I asked. All of our machines are set to "unity.""
My understanding is that this is only the case if you set your Mac's System Pref/Sound Output settings to use Kona to output audio which I don't do. For the very reason you mention (being vulnerable to your Mac audio output level).
Anyway, I don't think audio level is the cause of the issue here since:
1/ When the scratching goes away, no levels have been modified (just traying again)
2/ The deck shows a perfect -20db level on the tone
daryl burney
on Jul 27, 2008 at 3:55:29 am
Although I am in the PAL/50i world I have been having the same distorted scratchy (even though levels are correct) audio on layback to my HDW2000.
As with you, rebooting will usually make it go away.
Even though everything is locking and you can master to tape it IS a reference problem.
This is how I solved it..
Of course trilevel sync eg "Gen10" is a must.
Then set Kona to reference.
The trick is with the menu settings on the HDW2000.
Set to the following:
F2: REF
Menu 309: Auto2
Menu 334: Normal
If you have a look at the manual you will notice that these settings will keep the deck stable using the REF input at all times but will switch to INPUT when you actually start editing to tape ie locking to the incoming video. No loopback occurs using the above settings.
If you have an early HDW like mine you may also need Sony to do a firmware upgrade. The firmware upgrade will stabilise the reference/loopback that can occur when you are sitting in "edit to tape" mode (just before actual mastering).
Hope this helps. This is working for me after many months of distorted audio frustration.
regards
Daryl Burney
post supervisor
editlounge pte ltd
Singapore
