Change number of audio inputs?
Matt Larson
on Jul 13, 2007 at 3:27:16 pm
I just got FCP 6 and my Kona 3 (with version 4 drivers) set up and when I digitize I am getting 16 channels of audio, but I'd like to only have 2. I can turn the ones I don't want to capture off in the "Clip Settings" tab of the Log and Capture window, but those settings don't always seem to stick. I see that the "Input Channels" pop up is set to 16 but is greyed out so I can't change it there.
Is there a setting I'm missing somewhere in FCP or the AJA Control Panel?
Thanks-
walter biscardi
Re: Change number of audio inputs?
on Jul 13, 2007 at 3:36:56 pm
[Matt Larson] "I can turn the ones I don't want to capture off in the "Clip Settings" tab of the Log and Capture window, but those settings don't always seem to stick."
They will stick so long as you remain in the format you're capturing from. If you change that format to DV, then the panel will reset itself when you back to any format other than DV that can capture 16 channels of audio.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
