Kona Controle Panel Settings?
Shiloh
on Jun 28, 2007 at 8:40:40 am
Hello,
I have a question about the "color space" and "gamma" settings in the "codec options" tab in the Kona control panel. I am assuming that I should select the "Rec 601" and "Rec 601 (2.20)" settings for monitoring SD and the "Rec 709" and "Rec 709 (2.22)" settings for monitoring HD. If I'm correct, what would the "Linear (1.8)" gamma setting be used for? If I am incorrect can you please explain these settings for me?
Thank you very much for your time.
I am monitoring on a sony CRT broadcast monitor through the component out wile color correcting.
Shiloh
gary adcock
Re: Kona Controle Panel Settings?
on Jun 28, 2007 at 1:03:38 pm
[Shiloh] "what would the "Linear (1.8)" gamma setting be used for? If I am incorrect can you please explain these settings for me?"
for output to non broadcast displays or when capturing in realtime direct to a compression device for Live streaming.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
