Down Convert DVCPRO-HD 720p to Mini DV/DSR-11 through Kona
Michael Pierre
on Jun 28, 2007 at 2:43:16 am
I'm trying to take HVX-200 footage (which is currently in FCP sequence) and lay it off to DV/DSR-11 through my Kona 3.
Can't get it right. There is only a component out on the kona and only a standard RCA (yellow, red, white) on the DSR 11. So if I hook the Y/G/CVBS from the Kona up to the Yellow RCA on the DSR-11 all I get is the picture in black and white.
What am I doing wrong?
help please
John Pale
Re: Down Convert DVCPRO-HD 720p to Mini DV/DSR-11 through Kona
on Jun 28, 2007 at 6:15:31 am
Your deck doesnt have component connections.
It does, however, have S-video. The Kona can output s-video, but you need to buy a special BNC to S-video adapter cable.
http://www.kramerelectronics.com/cables/item.asp?desc=14
gary adcock
on Jun 28, 2007 at 1:01:30 pm
[John Pale] "The Kona can output s-video, but you need to buy a special BNC to S-video adapter cable."
why not just have the Kona output Composite video?
you can set the analog to composite video and then use the "Y/G/" connection for the video into to your DSR 11
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
John Pale
on Jun 28, 2007 at 2:25:46 pm
What Gary suggests is easier and cheaper, but S-Video will give you a slightly sharper image.
If you are unhappy with the quality...think about getting the cable, its not terribly expensive.
