drives to support lhe card
BabaG
on Jun 22, 2007 at 1:05:53 am
i just put a kona lhe card into my current system. (mac pro,
2x2.66 ghz dual core xeon, 5gb 667mhz ddr2 fb-dimm.)
i seem to be able to at least play 720p @ 23.98 8bit uncompressed
with the current drive setup. that would be a striped pair of
sata drives. i haven't finished testing, but know i can't play
anything 1080psf 24 8bit or above. what are the minimum drive
formats for various digital formats? is there a table somewhere?
in other words, what would scsi, iscsi, fibre enable that i'm
not getting now? i'd probably look towards getting bare materials
and assembling my own rather than buying something like an xserve.
thanks,
BabaG
walter biscardi
Re: drives to support lhe card
on Jun 22, 2007 at 1:11:55 am
Just go here and download the data rate calculator. Great little tool that tells you the data rate for various formats and how much storage you'll need.
http://www.aja.com/html/support_kona3_swd.html
Uncompressed 1080i you want around 225MB/s minimum.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
Bob Zelin
on Jun 22, 2007 at 1:27:23 am
Mr. G -
instead of saying "what is the minimum", how about listing what is the maximum you are trying to accomplish. Are you trying to do HDCam or SRW5500 4:4:4 uncompressed HD. Do you want 1080i uncompressed HD 10 bit, or do you want DVCProHD, or do you want HDV, or do you want DV ? Do you want it all ?
If you want it all, get a big mama disk drive array, that will cost you a lot of money. You will find, however, that you can "get away" with 2 SATA drives stripped RAID 0 inside your MAC Pro, and do everything up to DVCProHD. It will even do some Pro Res. And if you get a 5 bay SATA array, it will do all of this smoothly. If you want to do more - meaning uncompressed HD at 8 or 10 bit, now you need more drive, and a more expensive system. So you list what you actually want to do, and I will tell you the cheapest way to do it.
And while we are at it - is your real name Baba ?
Bozo Zelin
BabaG
on Jun 22, 2007 at 5:07:07 am
thanks for the replies. the card seems to go up to uncomp
1080p 10bit so i'd love to be able to do that. what kind
of throughput does that require from my drives and how
best to go about it?
thanks,
BabaG
walter biscardi
on Jun 22, 2007 at 10:31:22 am
[BabaG] "thanks for the replies. the card seems to go up to uncomp
of throughput does that require from my drives"
Did you download the data rate calculator? The throughput answer is there.
As for what to support it, I would say a very fast Fibre Channel array, possibly two striped together or two of these new super fast 8 to 10 bay SATA arrays. Probably in the neighborhood of $12,000 - $30,000 depending on the size of the storage.
BabaG
on Jun 22, 2007 at 4:02:21 pm
thanks walter,
"these new super fast 8 to 10 bay SATA arrays."
any more info on this? links? i have a 12 bay sata box now.
as for the data rate calculator, just looked at it but i'm not
on a mac right now and it appears to be mac only. know of anything
like it that's cross platform?
thanks,
BabaG
Sean ONeil
on Jun 22, 2007 at 5:53:40 pm
If you use ProRes and not Uncompressed, you can stick with what you already have.
Sean
