could i use a HD TV for a monitor if I had a Kona??
Micah Ginn
on Jun 19, 2007 at 3:19:10 pm
I really want to get a away from VGA monitoring, and I would like to buy a big HD TV and go HDMI in (or DVI) in and use it for my monitor.
Where can I read about how to do this with my G5?
thanks!
micah
walter biscardi
Re: could i use a HD TV for a monitor if I had a Kona??
on Jun 19, 2007 at 3:22:34 pm
Do a search on the forums.
With a Kona all you need is Comoponent input. That's what we use here. Or you can use HD-SDI inputs.
Panasonic Pro Plasma are the best out there for a really large HDTV and they come standard with Component inputs. Prices have fallen dramatically to about $1,100 for a 42" which is amazing.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
Bob Zelin
on Jun 19, 2007 at 10:08:45 pm
yes !
tell us the exact model # of the TV you want to buy, and I will tell you how to hook it up with the Kona product.
Bob Zelin
micah ginn
on Jun 23, 2007 at 6:58:56 pm
it's an Olevia 427v, but it's native resolution is 1366x768, which seems to be a problem.
I may be confused about what is possible, but what i wanted was to use this HDTV for my computer monitor to replace the little dinky 17" one i had. I bought this Olevia (a 27" HDTV), but hooking up with VGA is wildly unspectacular. Instead of having more realestate for editing, i just having everything BIGGER, and with less resolution!! Arggghh!!
sfrankiel
on Jul 10, 2007 at 11:28:16 pm
Hey Bob,
I am going to take you up on your offer. My boss wants us to use his old Sony KV-34XBR910 HD Television on our Final Cut station. We are running FCS 2.0, with a Kona2. What is the best way to use the TV as an output monitor (3rd monitor for video)?
I was thinking something along the lines of a AJA HDP Convertor (DVI-D to HD-SD/SDI). Let me know if I am on the right track.
~Sam
