FC Studio 2 and AJA Kona 3 10 Bit RGB Codec troubles
ruslan_3d
on Jun 19, 2007 at 12:20:09 pm
Our main pipeline is 1080i/p 24/25 Dual Link RGB video. We have Sony HDCAM SR and capture via Dual Link to Kona 3 10 Bit RGB codec prior 4.0 release. All thing was OK with 3.4 driver. Today we do clean install OS X, FCStudio 2 and Kona 4.0 driver. And I have troubles with RGB codec for now. I do Easy setup from "1080psf 24 RGB", change frame rate to 25 fps, field dominace to Upper. Capturing drom SR deck was OK, but when I put captured video to timeline I see only greenish lines and pixers on Kona 3 SDI Dual Link outputsADn Frame Buffer mode don't change to RGB-10 bit mode like in older releases. Same situation happen in all AJA utilites (AJA TV, VTR Xchange) and others. And after activation "Force RGB" in Color I lost picture and see Green Screen on my broadcast monitor. But this future works fine in old FinalTouch software.
Cans somebody check this issue with RGB modes in new 4.0 release?
best regards
ruslan_3d
