Multicam playback not what it was
msacci
on Jun 18, 2007 at 6:01:33 pm
I just put back my Kona3 card into my 8-Core, running FCP6 and multicam performance hit the floor.
Without the card it was fine, with it it is playing back about 2 frames a second. I have RT set to unlimited, Dynamic on both options, footage looks great it is just the frame rate. Tried Frame rate at Full and video quality at low and no change in rate or quality.
I also have a vertical band that travels horizontally on my analog video out - component.
msacci
Re: Multicam playback not what it was
on Jun 18, 2007 at 7:04:01 pm
Oh, footage is all DVCProHD 1080i 29.97. On 10 bay SATA Raid 0.
Worked fine in FCP5 and in G5.
walter biscardi
on Jun 18, 2007 at 7:35:15 pm
[msacci] "I also have a vertical band that travels horizontally on my analog video out - component."
You installed the new 4.0 drivers from AJA?
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
msacci
on Jun 18, 2007 at 7:40:50 pm
yes, and I'm wondering if that is what did it. I installed it a couple of days ago and just now but not until now did I need to uncollapse some clips to make edits. to a few sots.
JeremyG
on Jun 18, 2007 at 9:32:51 pm
You have run the expansion slot utility according to the manual so that the Kona is getting enough lanes?
msacci
on Jun 18, 2007 at 9:43:57 pm
Switch my system back to 5.1.4 and it is all golden.
Deadhead
on Jun 20, 2007 at 3:51:49 am
That is a good one to report to Apple. Sounds like an FCP 6 bug to me.
msacci
on Jun 20, 2007 at 4:28:50 pm
Or a problem with AJA driver since multicam plays back fine in FCP6 without the card.
