Erroneous Shift Fields Filter
walter biscardi
on Jun 18, 2007 at 1:05:34 pm
Just posted an entry in my blog that would apply to anyone opening a high definition project that was started / completed in FCP 5.1.4 and now opening in FCP 6. We're seeing erroneous Shift Field errors.
http://blogs.creativecow.net/node/213
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
tcurren
Re: Erroneous Shift Fields Filter
on Jun 18, 2007 at 2:53:19 pm
We've had this also. When you first open the project in FCP 6, it asks if you want to correct the shift fields filter from the previous version. DON'T DO IT! It adds shift fields with a -1 value to all of your shots.
Not sure what this is about.
Terence Curren
http://www.alphadogs.tv
http://www.digitalservicestation.com
Burbank,Ca
walter biscardi
on Jun 18, 2007 at 2:58:42 pm
[tcurren] "
Not sure what this is about."
Don't know either, this is a MAJOR issue that will completely screw up playback of any HD project. Have no idea how Apple missed this before the release. Only took me 5 minutes to find it.
msacci
on Jun 18, 2007 at 7:19:03 pm
Just saw that this morning, this I had a backup file I hit yes but it didn't seem to add a filter, would this be hidden away somewhere?
walter biscardi
on Jun 18, 2007 at 7:33:57 pm
No, it would show up in the Filters tab if it was really being added. Might have only added it to one or a few clips in the timeline or possibly not at all.
Either way, this message really should be taken away.
msacci
on Jun 18, 2007 at 7:37:46 pm
The timeline is concert so there are probably 500 edits, wouldn't want to double check them all.
John Pale
on Jun 20, 2007 at 2:11:24 am
If you are in a time crunch, you can temporarily remove the shift field filter from your plugins folder and your timeline will play back normally.
tcurren
on Jun 20, 2007 at 5:01:02 am
Now that's a tip worth slogging through all the crap. Thanks for thinking outside the box!!
Terence Curren
Burbank,Ca
tcurren
on Jun 20, 2007 at 5:05:54 am
On second thought, will you still be able to render? I've run into issues where FCP won't render when it is missing the filter someone applied in offline.
Terence Curren
Burbank,Ca
John Pale
on Jun 20, 2007 at 5:22:10 am
Havent tried this in FCP 6...but awhile back I did it in FCP 5.x and it was no problem at all.
