External monitor DELAY
TMjoey
on Jun 15, 2007 at 8:05:34 pm
Hi all,
This is driving me nuts. Off and on (mostly off) my external monitor is lagging behind by about 4 frames. Working with FCP 6, regular old SD uncompressed 10 bit. It could be a simple setting, but I'm not sure because it is not consistent.
Any ideas??
Joey
szumlins
Re: External monitor DELAY
on Jun 15, 2007 at 9:26:47 pm
Have you gone into System Settings -> Playback Control and set the offset to zero?
Default is 4. It should be 0 while using AJA hardware.
-Mike
TMjoey
on Jun 15, 2007 at 11:11:39 pm
Yep, but I have more info now and have somewhat isolated the problem, but now I'm not sure if it's FCP or AJA related.
If I click anywhere in my timeline and play forward, good to go. If I then pause and jog backwards, it's off (sometimes). If I then go forward without clicking in the timeline (l), it's off (usually), BUT I can always click the the timeline and play forward and it's fine.
Weird.
I can work around by clicking and clicking, but not productive.
Joey
